1) ETS TMIC, 3.5" - SOLD
2) CP-E Xcel Cold Air Intake - MS6 only. $175 SOLD
3) Custom turbo inlet pipe - aluminum, black, 2.5". Fits MS6/MS3. $100 SOLD
Or #2 and #3 for $225 total!
4) CP-E Standback II w/ PnP harness - Engine management system. MS6 only. $750
5) Redline Tuning QuikLift hood dampers - SOLD
6) Street Unit boost tubes - strong 5-ply silicon tubes that resist flex under boost. MS6 only. $50
7) Street Unit test pipe - 2.5", replaces 2nd catalytic converter, bolts up to factory exhaust. MS6 only. $50
8) AVE Electronics Navigation interface - allows 2 video inputs into stock nav screen, allows for backup camera. MS6/MS3/RX-8 (maybe more). $180
Or everything for $1500.
All items are in good condition, some used but clean, others brand new. Pictures and install help available.
PM or call me at 303-562-6289.
Parts for sale! MS6/MS3
- I`m Batman
- Rich
Batman, give me a call and you can come by to look at it.
Barn, the Standback comes with software that has preloaded settings for stock setups and for bolt-on setups. CP-E released these maps about 6 months ago, and they seem to be working well for people. Eric is running the bolt-on map with his GT28/FMIC/etc. and it works just fine. Because every car is different, you may find that these preset maps aren't exactly dialed in. In that case, taking the car to a dyno shop to have it tuned is the best way to go, unless you have experience in tuning. So potentially, you could spend another 200-300 refining the tune. If you would like to try the SB / PnP on a trial basis, I can help you install it and set it up...then you can run it for a week or two. I've probably had the most experience dealing with the SB on an MS6, so I have no problem helping out.
Rich wrote:ETS TMIC pending sale.
took long enough, who ever gets this is lucky at that price........
*CP-e CAI
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*RPM LED Side/Rear Markers
*SU Rear Engine mount
*Cp-e Rear Diff Mount
*TurboSmart MBC
*Turbo Inlet
*ETS 3.5" TMIC
*SU Test Pipe
*RPM Street Springs
*AeroForce Gauge
*TurboSmart MBC
- I`m Batman
