I got my car back on Friday and overall the paint looks good. When the car is in the light, I can see swirl marks all over the car where they did a bad job buffing.
What is the best get rid of these? I don't have a buffer.
I do have one of the Prima products but I can't remember which one, lol. Should I get the Prima Swirl?
"Swirl: A special medium abrasive for deeply cleaning paint and safely removing swirl marks without the use of waxes, silicones or fillers. Prima Swirl produces a smooth, swirl-free finish. It is safe and appropriate for all types of paint finishes, including clear-coat and freshly painted surfaces. Can be used by hand or with a machine polisher."
Light swirl marks
Light swirl marks
good to know, thanks.
Swirl works ok. Meguiars Ultimate Compound works really well. Prima, I like their glaze (Amigo) and The Banana Gloss wax, but don't "love" their other stuff. The Meguiar correction compounds (like 105, 205, and Ultimate) I've found work great. Start with the least abrasive (in this case, Ultimate) and go from there. A machine would really, really, really help, and you're welcome to borrow mine. The Megs stuff is available at local stores too, so it's easy to find (although I think the 105 and 205 seem to only come in larger (gallon or so) containers). The Megs Swirl X works well too. I removed decent swirls/scratches from the Tundra with that.
I talked to my dad and he says he has a buffer. He say it is a 9" but I'm not sure what brand, I'll get it tonight. What kind of pad should I get?
Dpends on what product you are using. If you are eliminating swirl, then probably a light to medium cut foam pad with the appropirate prouct. If you are using the Prima series, then you would need to follow up with a light cut pad with "Finish". People rave about Menzerna products. Apparently thy break down as you use them, so the same product covers a broader spectrum of polishing needs. Not sure how that works exactly.
Is your Dad's buffer a random orbital? I haven't dealt with a non-RO buffer.
http://www.menzernausa.com/menzerna-automotive.htm
My dad said his buffer is a random orbital, It wasn't where he thought it was when we looked last night. I'm going to look again tonight.
Dw, if I can't find my dad's than I may borrow yours thanks.
- The Driver
Sounds like you have some accessible resources at your finger tips Chris. I'd let any one of them rub my whip down, in a purely mechanical sense of course. Different strokes for different folks but it also boils down to polisher and polishing/application...not 100% product. But all essential variables for ridding your ride of swirls.
- The Driver
