Lookin' good.
So what do you plan to use for a hood?
RED 2jz FD (not finished)
- 7th Heaven
Haha, and the million dollar question goes to....
I will have to purchase tech2's custom 2jz FD rx7 hood specifically made for this swap. It is a 1000 dollar CF hood that i hope doesnt come broken when shipped and i hope that doesnt brake for a long time because that is too expensive to keep replacing. On the bright side i wont have to worrey about modifications to the chasis or my stock hood.
Go ahead and look up 2jzswap.com the yellow FD featured on the welcome page has the same hood i will be getting. Some people like it and some think its terrible. Im in between personally. let me know what you think of it.
- 7th Heaven
Full parts/modification list
Tech2 2jz/1jz Subframe kit-------------------2500
2jz-gte VVT-i Complete engine---------------4000
R154 5speed Transmission-------------------1000
Shifter extension----------------------------0350
C's short throw shifter-----------------------0350
ACT 650 ft lb Clutch-------------------------0850
OEM Flywheel-------------------------------0300
4in Intercooler kit w/ 3in piping---------------0650
Greddy RS blow off valve---------------------0260
Mid Sump oil pan swap-----------------------0350
2jz gte vvti Custom wire harness-------------1400
99spec style spoiler +paint-------------------0500
OEM headlamps and covers-------------------0350
New interior pieces---------------------------0600
Falken 245/35 ZR18 tires 265/35 ZR18 rear----1000
Custom Downpipe----------------------------0200
Will have ordered next month
Tech2 radiator kit----------------------------0650
Tech2 custom hose kit (samco)---------------0350
Mishimoto electric fans w/ aluminum shroud----0265
Adjustable fan temp controller-----------------0150
2jz starter-----------------------------------0250
Master cylindar------------------------------0050
Greddy arnix filter----------------------------0060
Banzai racing Differential Brace---------------0170
A/C delete serpintine belt---------------------0030
Custom throttle cable bracket----------------0045
2jz rx7 hood---------------------------------1000
custom Power steer resivor-------------------0100
Toyota inline fuel filter-----------------------0030
TOTAL--------------------------------------Expensive!!!
- 7th Heaven
Oh and these parts I forgot to mention
99spec front lip--------------------------------0200
Kenwood indash DVD flush unit-----------------0500
OEM manual trnasmission clutch/brake pedels---0230
Supra OEM dipstick and tube-------------------0100
pressure sensor solenoid-----------------------0050
Carbing Cooling plate--------------------------0200
Battery Relocation-----------------------------0100
Infinity rear speakers--------------------------0200
JDM Efini steering wheel-----------------------0200
Glow Shift Boost/water temp/pod package------0150
AEM air/fuel ratio------------------------------0300
HKS turbo timer-------------------------------0150
Greddy strut bar------------------------------0100
Rx7.com Smoked turn lamps-------------------0150
Bonez midpipe--------------------------------0200
Koni shocks----------------------------------I forget price
18in rims-------------------------------------I forget this too
- 7th Heaven
