Peanut butter
Peanut butter
Postby Huzer » Sat Apr 06, 2013 9:14
So, I got some polish on the black plastic bed caps. Tried an eraser, didn't work. Tried peanut butter, works like a charm. So, if you get wax on any of the black plastic bits, give peanut butter a try. It works!
Postby Number2 » Sat Apr 06, 2013 9:14
Thanks, I'll give this a try on the speed! There's black plastic around the foglight housing that I think has wax on it.
Postby kingtut » Sat Apr 06, 2013 9:14
Coincidentally, I just had a Nutty Professor (Crave peanut butter burger).
Now back OT: will the peanut butter remain edible, following the wax procedure?
Postby tsx_guy » Sat Apr 06, 2013 9:14
kingtut wrote:Now back OT: will the peanut butter remain edible, following the wax procedure?
I would imagine not sir
mOOsE
Postby mOOsE » Mon Apr 08, 2013 9:14
I'm so confused... So you put the peanut butter on your truck, your dog licks it off and it essentially cleans the plastic... Got it
:D
Justin
Postby Justin » Mon Apr 08, 2013 9:14
Damn, now I want a peanut butter cup.
Postby kingtut » Tue Apr 09, 2013 9:14
I'd guess this is common sense, but creamy variety is preferred over that of the chunky, yes? Nothing worse than peanuts gettting stuck in your trim
Postby Huzer » Tue Apr 09, 2013 9:14
Yes. And as always, YMMV. It worked on my truck, but I won't guarantee it'll work on your car. Try first in an inconspicuous area. I used PB mainly because I had nothing else around to try, so I gave it a shot.
