Electrical Issue Already
Postby Stealth01 » Mon Apr 21, 2008 9:14
OK, so when I used the four window controls on the driver's side yesterday, only the driver's window would go down. Not the other three. I noticed that the 194s in the doors were out, so I replaced them and magically, the windows worked again.
Then today, only the front and rear DRIVER'S side ones go down from that panel. Not the passenger side ones.
All work normally from their own button, and this time the door lights are functional.
Ideas?
GoToTheJoe
Postby GoToTheJoe » Mon Apr 21, 2008 9:14
Did you happen to disconnect the negative battery cable when you changed the bulbs? The Speed6 has a "feature" that you have to reprogram the windows whenever power is lost.
Roll windows down all the way with it's own button, then roll all the back up and hold for about 2 seconds. You will hear a clunking sound like a reset. Do that on all windows.
Not sure if it is exactly same since usually only the drivers window will operate from the panel and you are saying you have two working but might be worth a try?
--brian
2006 MazdaSpeed6 GT ** Whitewater Pearl Mica ** 5Zigen Pro Racer ZR+520 Wheels - Ceramic Bronze ** Navigation ** Integrated Sirius Radio ** Black and White Leather Interior ** 18% window tint ** Clear Bra ** Moonroof ** Wheel Locks ** MazdaSpeed CAI ** VG Sharkfin ** CF MazdaSpeed License Plate Holder ** Cargo Net ** Firestone Firehawk Wide Oval Indy 500 225/45r/18 ** Lamin-x Charcoal Headlight Protector **
<div class='quotetop'>QUOTE (GoToTheJoe @ Apr 21 2008, 05:42 PM) [url=index.php?act=findpost&pid=42161]<{POST_SNAPBACK}>[/url]</div>
Not sure if it is exactly same since usually only the drivers window will operate from the panel and you are saying you have two working but might be worth a try?[/b]
Yes, I did unhook the battery, so that is probably the issue.
That did it! Fixed. Thanks!
Postby tsx_guy » Mon Apr 21, 2008 9:14
<div class='quotetop'>QUOTE (Stealth01 @ Apr 21 2008, 06:51 PM) [url=index.php?act=findpost&pid=42169]<{POST_SNAPBACK}>[/url]</div>
That did it! Fixed. Thanks![/b]
RTFM j/k :lol: I had the problem after my CAI install and was about to post but then I decided to read my owner's manual and bam! done.
GoToTheJoe
Please take note that at 5:42p on 4/21/08...I became useful on this site!! That only took (how long has this site been up?) :)
--brian
TJditallo
Postby TJditallo » Mon Apr 21, 2008 9:14
lol I was just going to say check the window lock button because that would prevent the other windows from working as well but I did not want to make myself sound like a jack ass for sounding like a know it all. Glad u got it figured out though.
memphis
Postby memphis » Mon Apr 21, 2008 9:14
<div class='quotetop'>QUOTE (GoToTheJoe @ Apr 21 2008, 07:01 PM) [url=index.php?act=findpost&pid=42177]<{POST_SNAPBACK}>[/url]</div>
Please take note that at 5:42p on 4/21/08...I became useful on this site!! That only took (how long has this site been up?) :)[/b]
you are a GOD!!!! :25b530fa:
Over on the 6club, I got kinda scolded for not reading the manual. Apparently, it's in there. :D
TJditallo
I acttually picked up that tip form a dealler guy who was with me on my test drive for my car and he told me how to do it because the car we where in had had its battery disconnected. O and that way of "resetting" the windows works on any car with automatic windows and I would imagine that most cars have to be reset after having its battery disconnected.
goldrocket
Postby goldrocket » Tue Apr 22, 2008 9:14
Man I must be an old fart, I remember when window went up and down with switches that only needed voltage, not a computer......
Al says
Postby tsx_guy » Tue Apr 22, 2008 9:14
good for you...I am still trying to be useful.... :lol:
Postby RX-7 Chris » Wed Apr 23, 2008 9:14
<div class='quotetop'>QUOTE (goldrocket @ Apr 22 2008, 07:44 AM) [url=index.php?act=findpost&pid=42237]<{POST_SNAPBACK}>[/url]</div>
Man I must be an old fart, I remember when window went up and down with switches that only needed voltage, not a computer......[/b]
I was thinking the same thing and I'm not that old haha.
Users browsing this forum: Baidu [Spider] and 35 guests
