deepSpeedMS3 wrote:with rock chips in the hood...would you suggest a complete respray of the hood ot can you color-match touch up on the spots....im not an expert on paint so ill ask questions...by the way...where are you out of....(location)??
No, that actually just causes more problems down the road. Basically, if you just want to keep them from oxidizing and rusting down the road, yes it will work temporarily, but it will never look good.
Essentially, the best thing you can do to a hood is fresh paint and then clear bra it immediately after color sand and polish.
My cars all get beaten up at the track into walls, other cars, cones, etc. so I have no purpose of wasting the money on it, however it is awesome on a street driven car.
I am out of south denver (Hampden and Sante Fe)
speedjunkie wrote:I might have to have you redo my paint haha. Well actually it just needs to be wetsanded again and buffed, maybe some extra clear here and there, and it might need a bit of paint in just a couple spots but I'm not sure. I just got new wide fenders and need those painted too. I have a guy down here that does the work most of the time but the clear is spotty in a couple areas on my front bumper from when he painted it. Also, I'll probably be looking to get my rear fenders flared a little differently now since the front fenders look different (do you do body work like that?) and that will probably need to be sprayed again.
Wetsand and polish usually I dont like doing unless I was the one who painted the car, however I can do it, it just almost always turns into something you dont want it to.
Essentially, if you need some touch up with full reclear, that would be the way to go. Painting front fenders, and blending into the doors is pretty much perfect paint status.
Doing the rear fenders isn't a problem, but WILL require re-paint to make them look right especially in black. Basically, black sucks and black rocks, the same as white. What white hides on the panel, black shows (waves, inconsistency etc ). What black hides in the color, white REALLY shows (such as gaps, fitment, pinholes etc)
Black is not an expensive color, materials for a full respray would be around $400 for full black, full clear, along with sealer for the fenders. Then whatever labor I see fit for the work needed. FD's take a little while to dis and reassemble but other than that, not a problem.
memphis wrote:what would you charge to custom paint interior panels.. such as amp racks and sub box?
Tell me a color, give me an idea of what it is that needs sprayed.
Accessory stuff isn't a big deal and can usually even be sprayed without a booth, but obviously I will do it in a booth haha.
