Hawk Hps or EBC yellow pads
lOOkatme
Postby lOOkatme » Mon Jul 07, 2014 9:14
eliminster wrote:I switched to ebc yellows after hearing good things from speedjunkie and I have to say that they are a mean little brake pad. I have to say that there is no fade at all when running hard on them once you have them broken in.
I am running yellows right now and they are pretty good. The bluestuff is another step up from the yellows and are much better at higher speeds 100+mph braking. They are more consistent in grip at higher speeds + more heat, but the trade off is a little more dust, and more noise when cruising around. I am still running the yellows front and rear till they need to get replaced. I'll throw the bluestuff on after them.
