Left rear brake overheating Mazdaspeed 3
Hello all, I just went out for a drive in my 2008.5 Mazdaspeed 3 as the night was cool and clear. When I got home, I could smell a burning plastic odor. At first I thought I may have run over a plastic bag or something that may have hung up on the exhaust or catalytic converter. I opened the hood; could smell nothing; sniffed under the car; nothing. I started toward my house, opened my door, Nope. Checked the neighbor's house; nothing there. Could intermittently still smell the plastic. Went around the car again. Then I heard it: pinking, tinking. I reached for the left rear wheel and could feel the heat radiating off of it. The wheel itself was HOT! I checked all the other wheels. Definitely more than a hundred Fahrenheit degrees difference. All the others were reasonably and normally cool. It is too dark to see what may be the problem, and I will certainly take it to the dealership as soon as possible. What say Ye regarding the cause; and do you think the dealership will stick me with the bill since brakes are a wear item? This certainly is a defect or failure that I haven't caused. I have only about 11500 relatively easy going miles. All other brakes are working properly. Car was purchased July 2008.
Thanks guys for your replys. Rich, are you kidding? 4:20 a.m.? Just wanted to let all know that I drove it again this morning and all is back to normal. The rotor is not blue as I was expecting, but it does seem a bit glazed. I still will make an appointment to have it checked. This could be dangerous if the brake overheated this severely, at random times, and if I were to need it for emergency and it faded horribly or if the fluid had boiled.
Users browsing this forum: No registered users and 3 guests
