hello, i have a 2008 mazda3i manual with 130,000 miles. over the weekend i accidentally ran over a log on 285 and now the whole car vibrate. I have it re-balance and alignment and still vibrate so I took it to mechanic and he say i need to replace a engine mount. This engine mount is under the coolant reservoir. I search on advance auto part and there are two. My question is which one should i use or are these two are the same except one have to reuse the bracket.
Beck/Arnley Engine Mount http://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//27/large/10001730_bar_1041779_pri_larg.jpg
or
Anchor Engine Mount http://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage//27/large/20300833_anh_3103_pri_larg.jpg
thank you
engine mount
Re: engine mount
I've used Beck/Arnley products before with luck. I've never heard of Anchor.
Re: engine mount
The anchor link looks like it just replaces the center piece, so it depends on what part of the mount broke. I'd just go with the whole new mount system in your first link.
Users browsing this forum: No registered users and 82 guests
