Hello, I have an 08 mazda3 with a 120,000 miles. Last wee hit was stalling on highway so I put in sea foam with 91 Octane gas and it running fine now . I read that dirty maf could stall a car. My question is that since it running fine, should I mess with maf? And if yes, how much should I spray on and how far from the spray to the maf wire.
Thank you
Clean MAF sensor
Re: Clean MAF sensor
it wouldn't hurt to try. Just follow the directions on the can. make sure you use an actual maf cleaner.
