Turbos Demystified: How To Read Compressor Maps
Postby chickenwafer » Fri Dec 31, 2010 9:14
Turbos Demystified. How to read compressor maps
What turbo you pick for your car has a direct correlation on how much enjoyment you will receive from it. No one wants to wait through 2/3rd of the powerband for a turbo to spool, and on the other side of the spectrum no one wants a turbo that doesn't flow enough power for their goals and needs.
OEM manufactures realize this, and that is why OEM turbo system have turbos that spool within the first 1/3rd of their powerband, because this is where you spend the most of your driving. Not many people, aside from time attack road racers, spend any serious time near redline.
So first, we need to figure out how much airflow you require. There is a rather simple formula to figure this out, and you only need to do it once (for each boost pressure), then you can plot the figure on various compressor maps.
Pressure Ratio
First, complete the following equation to figure out your Pressure Ratio (PR). Pressure Ratio is defined as absolute outlet air pressure divided by absolute inlet air pressure. This formula is the only you will need to keep figuring if you want to change boost levels. There are a few different variables in here why we use the numbers we do, but without getting into the Ideal Gas Law, we can just use these numbers.
14.7 + Boost Pressure/14.7
For example:
14.7+ 15psi = 29.7/14.7 = 2.0 PR (Round to the nearest tenth)
The 14.7 represents ambient air pressure. Of course, at our altitude, we don't have this much air pressure. At 5000ft, we have 12.4psi of ambient air pressure. So, a more accurate way to calculate this would be the following formula:
12.4+ Boost Pressure/12.4
An example:
12.4+ 15psi = 27.4/12.4 = 2.2 PR (Rounded to the nearest tenth)
As we can cleary see, our pressure ratio is 0.2 higher than without accounting for altitude (which is a good deal). This points out why our turbos need to flow MORE air for a given PSI than at sea level, so they are working harder for a same pressure level than a turbo would be at sea level.
Also, if you have a lot of intake piping, such as a cold air intake with a filter and a large air box, you should also deduct another 1 PSIA from your absolute ambient air pressure. In our scenario, this would mean 12.4psia now becomes 11.4psia. This is to account of for restriction of your intake. You don't have to do this (I'm not in this example), but it will give you a more accurate PR.
Just a quick example, I will not use this again:
12.4 + 15psi =27.4/12.4-1= 2.4 PR
Now, we use the newly figured out Pressure Ratio (the Y axis on the compressor map) to figure out how much airflow you need for your desired boost level. To do this, we need some more information. So plug in the following formula:
(Displacement) (RPM) (Volumetric Efficiency) (Pressure Ratio)/5660
Displacement is easy, use your displacement in liters rounded to the nearest tenth. A Mazdaspeed3/6 would obviously be 2.3. For a rotary, we have to convert to piston math, so a 13B is 2.6L, a 12A is 2.4L, 20B is 4L.
RPM is the redline of your motor. Even if your motor doesn't make power all the way to redline, you need to plug in the highest RPM you're going to see, because even if power doesn't increase with RPM, airflow does. If your redline is 6000rpm, but you don't rev past 5500rpm, then plug in 5500rpm.
Volumetric efficiency is simply because no system is 100% efficient. For most systems, 90% is acceptable for Rotaries, 92-95% for 4-valve piston motors. To input this into the formula, enter it as a whole number, so 90% is entered as 90 (not 0.9).
Finally, the pressure ratio (PR) is the number we just figured out, which is boost-dependent, so it changes depending on what boost and RPM you want to run.
So, for example on a 13B-REW:
(2.6L) (8000rpm) (90%VE) (2.2)/5660 = 727.6
The number we just received is our CFM (Cubic Feet per Minute), which is a volume measurement of a gas, in this case, air.
So now we have an air flow requirement of 727.6 CFM. So what? Of course, turbo compressor maps have air flow in LBS per Minute (Lbs/min) on the X axis. So now, we need to complete yet another conversion to get our CFM into lbs/min.
Formula:
(CFM) (0.069) = lbs/min
And our example:
(727.6) (0.069) = 50.2 lbs/min
One quick way we can calculate power is 1 lb/min of airflow is equal to about 10rwhp. So, for 50.2lbs/min of air, this should be 502rwhp. This is just a ballpark, but it should get you close. Rotaries require more airflow per horsepower than piston motors, so for rotaries the forumla is 7.69 rwhp per 1 lb of airflow per minute. So in our example this would be 386rwhp. This is why turbo sizing for rotaries is so different, and why rotaries seemingly run larger turbos for less power. If you rotary is streetported, add 10% for the horsepower calculator. Bridgeports can add 16-18%.
To take this method one step further and to compensate for our altitude, we loose about 10% power up here. For the 10rwhp per 1/lbs of air in piston math and 7.69rwhp per 1lb of air for rotaries doesn't hold true up here, it's 10% LESS. So 1lb of air is 9rwhp for pistons and 1lbs of air is 6.92rwhp for rotaries. Or just figure your horsepower number using normal math and then subtract 10%.
And now these are the numbers we use to plot on our compressor map. The vertical axis/y axis is the Pressure Ratio, which in our example is 2.2. The horizontal axis/X axis is in lbs/min.
On the compressor map, there are what we can "efficiency islands". The turbo is most efficient in the center of the map. Think of the map as a geographical topographry map, with the center efficiency island being the highest point (like a mountain), and the map getting smaller as it spreads out. You want to be as close to the center as possible on the map to be in the best efficiency range. Too far to the left of the map and you will surge (the turbo is pumping more air than the engine can ingest), and too far to the right and the turbo will become a restriction and starve your motor, also known as the choke line.
So now, let's plot what we just did in our example on a Garrett GT3582R compressor map. The PR is 2.2 and the lbs/min is 50.2 (or 50lbs/min):
As we can see in our example, this turbo (Garrett GT3582R) is perfectly suited for our application. North or South doesn't matter much, as long as we stay within the main efficiency island. This would offer great turbo response and airflow. This turbo would also give us room to grow, let's plug in our formulas to see how much power we could ring out of this motor on our example engine.
Example:
12.4 +18psi =30.4/12.4 = 2.4 PR
(2.6L) (8000rpm) (90%VE) (2.4 PR)/5660 = 811 CFM
(811 CFM) (0.069) =56 lbs/min
Alright, so we went from 50.2 lbs/min of airflow required at 15psi to 56lbs/min of airflow for 18psi. This should equate to 431rwhp in rotary terms, 560rwhp in piston math.
And replotted on the map:
We are off the main efficiency island but still within the means of the compressor. So, let's go for broke and see what we can do with even more boost on our sample motor:
12.4 + 24psi = 36.4/12.4 = 2.9 PR
(2.6L) (8000rpm) (90%VE) (2.9 PR)/5600 = 959 CFM
(959 CFM) (0.069) =66 lb/min
So at 24psi we are pushing 66lbs/min of airflow on our 13B-REW 2-rotor Wankel. This should be 508rwhp on a rotary, and 660rwhp on a piston motor.
Let's plot it:
Basically off the map. We are at the point where the turbo can't supply enough airflow for the motor and could become a restriction. Also, the air is becoming super heated at this point, because the compressor is being over-spun.
So now we know the GT3582R is too small is we want to flow 66+ lbs/min of air on our example motor. So lets plot this on a larger compressor, such as the Garrett GT4294R:
Boom! Basically on the main efficiency island of the GT42R. Again, this is for a rotary, but we can see this turbo would be the best choice here. Although, this doesn't mean the GT35R wouldn't be a good option, although it would be ill advised.
OK, enough rotary stuff, let's show the Mazdaspeed guys some love. In this example, we can even work backwards, starting with what horsepower we want. For this, lets say we want 400whp.
Formula:
400whp/10 = 40 lb/min
40 lbs/min/ 0.069 = 580 cfm
Okay, we know now we need 580 cfm in order to get 400whp on our Mazdaspeed3/6 (the MS6 might need slightly more because of the higher drivetrain loss).
12.4 + 20psi = 32.4/12.4 = 2.6 PR
(2.3L) (6000rpm) (95%VE) (2.6)/5660 = 602 cfm
(602 cfm) (0.069) = 42 lbs/min
So a little strong, but we're pretty damn close. This means, for out alltitude, you would need to run 20psi to get to the right PR. Now we can look at some compressor maps and see which one will give us the best trade offs of power and spool.
Here's a GT3071R:
A pretty good match. We are just a little to the right of the main efficiency island but pretty much spot on. The GT3071R would be a great 350whp-450whp choice for Mazdaspeed cars.
In the last example, we worked backwards by first figuring out how much power we wanted. This is easy because 10rwhp = 1whp, so simply move the decimal point over one spot to the left. 50lb/min of air is 500whp (again, this is a ROUGH estimate, but it will get you close).
We can also do this for a rotary, but as I outlined in an earlier post, the formula is different. Say we want 500rwhp in our single turbo FC.
500rwhp/7.69 = 65 lbs/min
So we know we need 65lbs/min of air to make 500rwhp on a rotary. This applies for any rotary; 12A, 13B, 20B, etc.
This makes it quick and easy to look at compressor maps on the fly. The Pressure Ratio is easy enough to figure out. Then, with a quick glance at the map, you figure out the most power that compressor can support.
Let's look at a GT4088R compressor map:
We can see this turbo flows around 68lbs/min of air at a PR of 2.3. So this turbo can support roughly 680rwhp on a piston motor and 523rwhp on a rotary. Again, this is at a PR of 2.3, so you need to calculate where you will be at for your airflow requirements.
Here is another turbo I am real excited about; the new Garrett GTX3582R. This features Garretts new Billet comp wheel. In case you haven't heard, billet wheels are all the rage now because they are over 40% lighter than traditional/typical cast wheels, which means quicker spool, lower discharge temperatures, and greater power potential. Really, there are NO drawbacks to a billet wheel, besides cost. If you can afford one, GET ONE!
Here is the GTX35R comp map:
We can see this turbo supports 78lbs/min of air at a PR of 2.8! That's 780whp on a piston motor and 599rwhp on a rotary! Of course, this is off the good efficiency islands so you're running on the bleeding edge.
The GTX35R is happiest in a wide range of airflow, around 40-60lbs/min and at PR's of 2.0 through 3.0. That's a pretty broad range to be on the main efficiency island, proving just how flexible this new compressor truly is.
Using our previous example where we fell off the standard GT35R's map, we had 66lbs/min at a PR of 2.9. We were just on the map with the old cast-comp wheel GT35R, but the GTX35R is comfortably supporting those requirements. Go billet!! I would love to map out a Precision 6262 billet (the turbo I am probably going with on my single turbo FD build) but getting a compressor cost a considerable amount of money. Precision is a small company that stuffs proprietary compressors and turbines in Garrett CHRA's and some Garrett/Turbonetics housings (Turbonetics also modified Garrett cores). So, Precision has no compressor maps.
Here is a quick cheat-sheet I came up with for Pressure Ratios for given boost levels. These are the same for all motors, and only vary with ambient air pressure (altitude) and desires boost level (these were all figured with an ambient psia of 12.4 for 5000ft of elevation):
10psi=1.8PR
12psi=2.0PR
14psi=2.1PR
16psi=2.3PR
18psi=2.45PR
20psi=2.6PR
22psi=2.8PR
24psi=2.9PR
26psi=3.1PR
28psi=3.3PR
30psi=3.4PR
32psi=3.6PR
And there you have it! It's not that difficult, and with just a little math you can be selecting the perfect turbo for your application. Post up any questions you have and put up some maps and we can work them out!
Thanks!
Postby erod550 » Fri Dec 31, 2010 9:14
What would the flow differences be between a GT3071R and a GT3076R? Would either be the best choice for 350whp or would you be better off getting a GT2871 or 2876 for better response while still meeting that power goal?
Here's a GT3076R comp map:
And a GT3071R comp map:
We already figured for roughly 400whp on an MS3 you need 42lbs/min of air at a PR of 2.6.
Plotted on the GT3076R:
And on the GT3071R:
We can see the GT3071R will handle it comfortably (on the 3rd main island) and be a good trade off for power and spool. The 76R is going to have more room to grow and will produce lower compressor discharge temps for the same boost level as the 71R, at the cost of a greater boost threshold.
(sorry the comp map pictures a little large, it's the first ones I found)
The GT30 series turbos are really well suited for two main motor types, medium displacement, high revving, low boost applications or small displacement, low revving, high boost applications (such as the MS3). High boost would be over 25psi, because look at the map, it goes to a Pressure Ratio of 4 (37-38psi)! At this level, again, you're on the bleeding edge, but still, this turbo can handle it.
http://www.calctool.org/CALC/phys/default/pres_at_alt
That calculator says the ambient air pressure would be 11.8 at 5000 ft. Not saying that is correct, but it could affect your calculations. I was using it to do the math for 6200 ft, as we're a little higher down here than you guys up north.
The 12.4psia figure came directly from Garrett. I've seen variations myself. Most common is 12.6, 12.4, and 12.2. I've never seen 11.8, that figure would probably be more accurate for your elevation of 6000ft, however.
Alright erod, let's figure out a GT2876R for 400whp on an MS3 and see if it's a good match.
We can also plug in your 11.8psia figure for your higher elevation. We will also need a little more boost.
So:
11.8 + 21psi/11.8 = 2.7 PR
(2.3) (6000RPM) (95%VE) (2.7PR)/5660 = 592 cfm
(592 cfm) (0.069) = 41lbs/min of air
So this gets us 41lbs/min of air required at a PR of 2.7.
Plotted on the GT2876R comp map:
We can see this is still acceptable. The GT2876R might be the hot ticket. 400+whp capable and excellent spool. The billet version (GTX2876R) would be even better.
OK, lets use the same GT3071R turbo (same turbo I had on my old RX-8) and try to hit a shade over 400rwhp on an RX-8.
So...
12.4+16psi/12.4=2.3PR
(2.6L)(8500rpm)(90%VE)(2.3PR)/5660=808cfm
(808cfm)(0.069)=56lbs/min
So, for an RX-8, 16psi = 2.3PR & 56lbs/min
And for horsepower:
(56)(7.69)=431rwhp
Plotted on the GT3071R comp map:
And we can clearly see we're not even CLOSE to the map! The turbo has become a major restriction and is choking airflow to the motor. The air is becoming super heated as well. This turbo would be a bad choice for our altitude for an RX-8 looking for more than 400rwhp. For less, it's a great turbo, however.
400whp would require building the bottom end which I'd prefer not to have to do. Looking at where you plotted 400whp at 11.8psia, 350whp should be slightly lower and to the left, right? Which would put it right in the sweet spot of the GT3071R if I'm reading this stuff correctly. Looks like it will also be feasible on a GT2876R which will have a little bit quicker spool, and even though I'd be closer to the higher end of the turbo's capabilities, I seriously don't think I'll ever want more than 350whp in a FWD car, so that should do what I need it to do.
The difference is only going to be a couple hundred rpms of spool time though right? And a GT3071R would allow me to run lower boost and make the same power as a GT2876R, thus lowering temps all around?
The 3071R is going to be a more efficient compressor, but for 350whp the 2876R will be fine, because you're pretty much be on the main or at least the 2nd efficiency island of the compressor. We're splitting hairs at this point, both will be extremely efficient and the 2876R will offer better boost threshold. The best option would be the GTX2876R because of the billet wheel...even better response and threshold than the standard cast-comp wheel 2876R and essentially GT3076R output. Win/win. It's not out yet, but will be soon. No compressor maps are available yet, however.
There are two things to consider when we talk about "boost response" as well:
First is Spool, Boost response, start spool, etc. Basically, this is the time from cruising in vacuum when you put your foot down and ask for power, to the turbo generating positive manifold pressure. It doesn't mean your turbo getting to X psi!
When you're talking about a turbo getting from first hitting positive manifold pressure (1psi) to your target boost of say 20psi, this is Boost Threshold. Boost threshold is the term 98.7428362% of people misuse and don't understand, and is probably the most important term in regard to sizing your turbo properly.
Even a laggy as hell turbo, such a GT4088 on an MS3, will hit positive manifold pressure within a few seconds at most of you putting your foot down. The problem is, the pressure will hang there at 0-1psi while the compressor starts to spin and generate boost. It will slowly create boost as RPM's rise and then, in most cases, boost will come on strong at a certain RPM (in the top 1/5th of your power band, generally) and all your power will hit hard. An example is a 1400rwhp Supra with a T88, which makes 150rwhp until 6,000rpm then makes 1200rwhp in a 1500rpm window...essentially all at once.
Yea the billet ones sound nice, but they're also half again as much money as the standard ones. I don't even know if I'm going to go with a bigger turbo on this car but this is all good info to have if I ever do decide to go down that path.
Billet is a large investment, but there are basically no drawbacks to getting one, besides the high entrance fee. For example, the GTX35R is $2000 without a turbine housing, whereas the standard dual ball bearing GT3582R is $1350ish all day. So you're looking at almost an extra $1k just for the billet compressor wheel!
Is it worth it? Well, if you're a boat like me, where I don't really need the extra head room provided by the billet wheel (although the better spool and boost threshold would be nice), it's not offset by the extra cost incurred, so no, not really. If the billet wheel was say, another $500 bucks, then I would probably spring for it.
Also, deciding on the Precision 6262 Billet turbo is more difficult, because like I outlined earlier, Precision does not release compressor maps! So it's kind of shooting in the dark. The 6262 features a 62mm comp wheel, but since it's billet, it's not a simple apples to apples comparison to another 62mm turbo because of the billet wild card.
Eclipse
Postby Eclipse » Sat Jan 01, 2011 9:14
I would love to see you do this with the stock k04 turbo on the speeds.. Lets see how inefficient 18psi on the stocker REALLY is..
