HPFP (High Pressure Fuel Pump)
Postby Number2 » Fri Feb 15, 2013 9:14
I'm going with the Autotech HPFP internal upgrade from Edge Motorsports. Looking at a late March install.
-Fuel Pump upgrade
-Corksport Turboback Exhaust.
Anyone else looking to do an 'Install' day in late march?
pyrrhus17
Postby pyrrhus17 » Thu May 09, 2013 9:14
Hey number 2 can could you do a Diy with pic's (any chance)
Postby Number2 » Mon May 13, 2013 9:14
pyrrhus17 wrote:Hey number 2 can could you do a Diy with pic's (any chance)
Hi Pyrrhus,
I had the fuel pump internal upgrade done by a professional, as I didn't trust myself to do this upgrade. I have no pics along the way, but I will say that it is a fairly straight-forward upgrade, and that no engine components need to be removed besides the intercooler shroud. Also to note, you will need a good vice that will hold the fuel pump in place while the new one is installed.
It should be about one hour's work if you decide to take it to a shop.
Mortose
Postby Mortose » Tue May 14, 2013 9:14
its really easy, all you need is a torque wrench, an inverted E8 socket, and a Deep 18mm Socket. there are a couple vids on youtube on how to do it. i went SUPER slow doing mine and it only took about an hour.
Postby Number2 » Tue May 14, 2013 9:14
Also, there's a great tutorial with pics on the other forums.
Andyscums
Postby Andyscums » Tue May 14, 2013 9:14
Mortose wrote:its really easy, all you need is a torque wrench, an inverted E8 socket, and a Deep 18mm Socket. there are a couple vids on youtube on how to do it. i went SUPER slow doing mine and it only took about an hour.
If I kicked you a couple bucks would you walk me threw mine and help me with them if I drove down to the springs? I contacted edge but the wait is almost 3 weeks and I want to do my dp and stuff but am waiting on these before I do
Mortose
its all good man, just come down and we can knock it out. no worries.
_AlexTM
Postby _AlexTM » Tue May 14, 2013 9:14
Mortose wrote:its all good man, just come down and we can knock it out. no worries.
I want hangs...:D
SOLD 2004 Mazda3 hatch
