Got that task done today. Was a little easier than I thought, but a hell of a lot messier. Still, there are now ALMOST 3 quarts of Redline MT-90 goodness in the MTX, and she shifts SMOOTH. Noticeable difference.
That said, the old fluid actually looked pretty good. I think it might have been changed somewhere along the way.
Tranny Fluid Changed
Yep, definitely shifts smoother now. But that could just be because the old fluid was...well...old.
Stealth01 wrote:Got that task done today. Was a little easier than I thought, but a hell of a lot messier. Still, there are now ALMOST 3 quarts of Redline MT-90 goodness in the MTX, and she shifts SMOOTH. Noticeable difference.
How did you approach your change? I think I recall reading two different methods. One using a funnel with a long hose, and another.
he isn't really on here anymore.
I use a pump to fill the tranny.
I use one of these from the parts store:
You can find it locally. And you can have my 3 QTS if you want it. I picked mine up at http://www.3rauto.com/
Huzer wrote:You can find it locally. And you can have my 3 QTS if you want it. I picked mine up at http://www.3rauto.com/
Sold. pm inbound!
on a fwd you can't add the fluid through the shifter.
I'm a slacker...still need to do this.
edit:
Not a very difficult task. It would have been a little more awkward with te car only on jackstands, but not difficult still. I changed mine at 75k. The 2-3 shifts now have no clunk to them. I also used the Redline MT90. Thanks to Huzer, I only needed to buy 1 qt. Need to get one of my own pumps though. Seems like a good thing to do more often (every 30 k perhaps).
edit:
