Some of the Colorado Springs folks already know about this, and some thought it was kinda ridiculous. Well, it is, but I decided to do it none-the-less. It's fairly cheap too. I decided to do this for two reasons...
1. I love homemade stuff. I would much rather make something for the car than buy it off the shelf. I also love products that others on the forums make, things like air pump deletion idler pullies (which I also have), etc.
2. I figured instead of a coffee can exhaust, I could have a coffee can intake haha.
So I started with a 39oz Hills Brothers Original Blend coffee can. I also got a 6" metal end cap, a 2" plastic T fitting, an adapter (to serve as the backing to attach it to the end cap), a flush valve shank washer (to use between the adapter and end cap) but I ended up not using that.
This is the first set of things I bought at ACE Hardware (except for the coffee of course)...
...but I had to go to Lowe's and get a different size T fitting so I could attach the ducting. The first one I got was 1.5", the second one is 2".
I started by cutting the bottom of the coffee can, to make the hole for the filter to slide through...
I left the little tabs so that I could tighten the clamp around them to make sure the can stayed upright and didn't sag...
And I had to cut the top of the can to get the filter inside, and to be able to slide the end cap in when it came time...
Then I did a test fit on the turbo, not too bad.
Because the vacuum line coming off my turbo was kinked due to the coffee can, I got an elbow fitting while I was at Lowe's.
Then I started on the end cap assembly. First I cut a hole to slide the adapter through and attach the T fitting. I was going to put it right in the middle of the end cap, but I figured if I offset it, it would clear the filter more and let air flow better.
Due to the VMIC, it is a tight fit for the can with the end cap and T fitting installed, so I had to cut the can down a bit.
I think it the can will need to be cut down a bit more, and I also cut a little off the back of the adapter so it won't hit the filter. I wish I could cut the T fitting down some, and I might try that, but I'm afraid it will mess up the threads and make it unusable. Tomorrow I will clean it all up and do a proper test fit onto the turbo. When I'm happy with it all, I'm going to cover it with heat shielding to keep it as cold as possible inside.
Info for the parts I'm using are...
Parts bought at Lowe's
2" plastic T-fitting
bar code 39923 20942
C5814
$6.25
2" plastic adapter
bar code 39923 19472
C5804
$1.33
(if you need it)
elbow fitting
bar code 48643 07203
Watts A-712
1/8" MIP x 1/8" FIP
$2.64
Parts bought at ACE Hardware
6" GV End Cap
bar code 63467 14404
GV0735
$7.99
The heat shielding is a DEI 12" x 24" piece I bought from Advance Auto Parts for about $20, but I might try to use something that doesn't have an adhesive backing so I can remove it easily if need be.
Oh, and the filter I have is a K&N RU-2510.
Air intake box
LOL I got your text on this. Funny stuff, hope it works.
You need to post this on thereifixedit.com.
After some feedback on Rotary Car Club got me thinking about restriction, I decided to give each duct it's own opening. I used two adapters (like I was using to attach the T fitting) and trimmed them down a bit to make more room for the filter. The pic is of a regular one and one that I trimmed down.
I also realized today that the T fitting openings weren't actually 2", they were closer to 3". The threads on the adapter are close to 2.5" so I left them installed threads out and I ordered 12 feet of 2.5" diameter ducting. I believe tightening the ducting down on the threads will help it stay on as well.
I put on the heat shielding too, but it was a pain in the ass since like a dumbass I measured and cut it first instead of putting it on THEN trimming off the extra haha. I also put some on the cover since I had enough leftover. I might put on a second layer of shielding since the first layer is kinda jacked and also because you can still tell it's a coffee can haha.
I also discovered that I have enough space on the sides of the VMIC/radiator to put the ducting ends through there on both sides, so I may not do a headlight swap now. The only thing I'm curious about is if using that area as an intake for the turbo will take too much air/pressure away from the VMIC/radiator.
Users browsing this forum: No registered users and 28 guests
