Request: Throttle Position Sensor Change
The How-To Forum
Pharmgirl
Postby Pharmgirl » Sun Aug 09, 2009 9:14
I have a 03 6s and the diagnostics say my throttle position sensor has/is bad. :( Has anyone changed one of these out? I haven't torn into it looking for the throttle body yet, but it is not very obvious from the top where it is located.
Also, apparently these lovely sensors have to be ordered directly from Mazda, so I am sure they aren't cheap! Anyone have experience with this that could give me some pointers?? Or if there is a technical service bulletin about it? Thanks!:)
Postby dommo_g » Sun Aug 09, 2009 9:14
Call me tomorrow. 303.678.8950. Ask for Domonic. Be sure to let me know its you that I'm talking to.
Postby AIM WO4 » Sun Aug 09, 2009 9:14
Can you do just the sensor? I had to do the entire TB on the Saab.
Postby chickenwafer » Sun Aug 09, 2009 9:14
I'm pretty sure the TPS is built into the Throttle body. You will more than likely need to swap the entire TB
Cesaros
Postby Cesaros » Mon Aug 10, 2009 9:14
Pharmgirl wrote:I have a 03 6s and the diagnostics say my throttle position sensor has/is bad. :( Has anyone changed one of these out? I haven't torn into it looking for the throttle body yet, but it is not very obvious from the top where it is located.
just for future reference...the TB is the big silver metal sqaure bolted to the intake manifold...its easily located by following the big black stock rubber intake tube from the air box.
Postby dommo_g » Mon Aug 10, 2009 9:14
Throttle Body - AJ57-13-640C - $271.10
Gasket - AJ03-13-655 - $6.52
Sensor can't be bought separate from the TB. Let me know if you want to do this, I'll give you a hook up on prices.
Pharmgirl
Postby Pharmgirl » Mon Aug 10, 2009 9:14
Thanks for the help! ;)
I am deciding on my next steps, especially since the price is a bit steep.
Has anyone heard about a technical service bulletin for this?
Postby AIM WO4 » Mon Aug 10, 2009 9:14
You need to PM him for a price.
Return to “DIY”
