need help speed 6 atp dp install
The How-To Forum
04rx8
Postby 04rx8 » Thu Mar 03, 2011 9:14
Hey guys trying to get the stock dp off need some tips to get the 5 bolts off the dp that connects to the turbo and getting it out.
Eclipse
Postby Eclipse » Thu Mar 03, 2011 9:14
take the alternator off with the three bolts holding it in place, and let it hang down, makes life much easier
Powerstroke 6.0
Postby erod550 » Thu Mar 03, 2011 9:14
Yea I've heard the alternator makes life hell getting the DP off on the MS6. With my MS3 I just used a lot of extensions and u-joints so I didn't have to try to get the ratchet down in there. Also, liberal use of PB Blaster helps, especially because your MS6 probably has a lot more miles than my MS3 had on it when I did my downpipe.
Postby movovr » Thu Mar 03, 2011 9:14
OCD wrote:take the alternator off with the three bolts holding it in place, and let it hang down, makes life much easier
Listen to this man ^
rmeeker13
Postby rmeeker13 » Thu Mar 03, 2011 9:14
+1 on the alternator removal, also use plenty of penatrating lube on all nuts/studs and o2 sensors, if they've been in there awhile which I assume they have they end up welding themselves in their. If you need any advice OCD and I have done it many times!
Return to “DIY”
Users browsing this forum: No registered users and 24 guests
