Ugh, stupid forum logged me out after typing a long post. Here goes again.
speedjunkie wrote:I'm not an FC guy so I don't know as much about them, but I'm sure we can find someone to help. We have a few FC guys in C Springs and we could probably take a cruise up to help you sometime.
I appreciate the willingness to help! I might take you up on that]I'm sorry to hear that you're still having problems with your car. Can you elaborate on your statement above? In other words, did the car run fine before (with your current setup) or did you install something new that might be the culprit? Do you have a working baseline that you can revert to?[/quote]I appreciate the help. It's a very long story, so I'll try to be brief. Please ask clarifying questions as needed.
In the summer of 2007, I had a more basic setup with a S-AFC for fuel control, that was basically the only aftermarket electronics I had. The car ran perfectly. During the summer I was on a road trip, and all the sudden something happened to the car and it started to run differently. My memory is a bit fuzzy now, but I believe it started to "buck" around the transition to the secondaries. I also think it felt less powerful. I elaborate more in detail on the problems in the threads immediately below. At that point I did have the V-Mount, bigger turbo, etc, but again most the electronics were stock besides S-AFC, fuel cut controller, my current injectors, and fuel pump. No aftermarket ignition control.
I found some old threads I posted on RX-7 club (with videos) that describe how it was back then. I will say that after reading through it, I don't think I ever solved those problems, I think they were the beginning of the path that led to where I am now:
http://www.rx7club.com/2nd-generation-specific-1986-1992-17/series-problems%3B-flooding-rich-starting-etc-669290/,
http://www.rx7club.com/2nd-generation-specific-1986-1992-17/runs-rough-terrible-cold-start-fuel-cut-help-719263/I installed a Megasquirt but I couldn't get the car to run on it; I was in over my head, and I couldn't really find any good help on it so I gave up.
Here are threads I made about problems with the Megasquirt:
http://www.rx7club.com/megasquirt-forum-153/i-need-your-help-asap-%5Bpictures%5D-612377/,
http://www.rx7club.com/2nd-generation-specific-1986-1992-17/ignition-ecu-problem-615952/Then I moved to Haltech PS1K. I wired and installed it myself. I did a base tune. It was better than now, but still didn't run well at all--it was "choppy", didn't idle well, just didn't feel smooth, never transitioned well into secondaries or boost. It also developed some other weird problems, like for example it wouldn't turn off unless I pulled the parking brake. It still does that with the AEM; Don thought it had something to do with the alarm system, but he never was able to fix it.
And threads I made about problems with the Haltech:
http://www.rx7club.com/haltech-forum-62/ps1k-misc-problems-854649/,
http://www.rx7club.com/haltech-forum-62/fuel-setup-947057/In desperation, I called Don Walker, and he said he was confident that he could get it running well on AEM. Basically I had this idea that if I just replaced everything electronic in relation to the engine it would "fix itself", because if something was broken it would have gotten replaced. Don installed the AEM, new (different) coils, a new (custom) CAS, fuel injectors were cleaned and tested, fuel filter replaced, fuel pump replaced, installed an aftermarket fuel pressure regulator, new spark plug wires, etc. But none of these things seemed to solve the problem--he said they all made some improvements (like he said I wasn't getting consistent fuel pressure), but obviously he never was able to get it running well. He installed like 2-3 variations on the ignition setup; I'm not even 100% sure what he has now, but I think it's Tahoe coils (not the RX8 coils and 3000GT igniters as stated in my sig/website).
Somewhere in here, I rebuilt the motor at least once (or maybe even twice, it's funny I can't remember exactly). All I know is that the motor now has very few miles on it, probably less than 500, and should have perfect compression.
But here I am, nearly 3 years later (after giving the car to Don to fix and install AEM), and it's still not running well at all. I gave up on Don because he was just too slow and became completely unresponsive when he moved to CA. I just didn't have confidence he'd ever fix it--he had it for almost 3 years continuously. He said all it needed was a tune, that all the hardware was in place, but the passenger carpet is up because apparently he was still doing something with it--I think trying to troubleshoot some of the weird issues.
When I say "doesn't really run" what I mean is, it will start (with help; not exactly quickly but not exactly slowly), but after that, it's very choppy. It sounds very strange, as if its under a lot of load or something, and it's a real chore to get it to move under its own power. It really doesn't want to; I have to slip the clutch to get it move or it will stall. After a few start attempts, once it starts to warm up; it will actually idle by itself. But that's about the limit of its "normal behavior". It backfires heavily on engine deceleration, and won't rev up past 3-4K RPM, it just chokes and "hits a wall" that it bounces off of, almost like a rev limiter. It doesn't rev up smoothly either, it definitely struggles before it hits that wall.
So to answer your question, no, I don't really have a baseline to return to. The last time it ran well, as described above, was way back in 2007 when all I really had was an S-AFC; but that's when the problems started--before that the car was basically stock. But it ran fine with S-AFC for a long time and made decent power, but not what I wanted.
As you can see from my forum posts above, I've been at this for a long time, and honestly my patience is very, very thin. I wish I could just give it to someone who could fix it, I'm feeling pretty desperate and discouraged as I said in my OP. Help is definitely very welcome. I also feel like I got burned by Don, so that doesn't make me feel any better either. I'm pretty close to just cutting my losses and moving onto an FD with reliability mods, but I don't want to get rid of my FC because I love it and have a lot invested in it; it was my first car too.
I've always had this sneaking suspicion it's something dumb or trivial, like a vacuum problem, TPS problem, or an injector is faulty or something. But I guess I'm skeptical that it's that simple too. Maybe Don is right, maybe all it needs is tuning, but the way it's running now it *feels* like someone else is wrong, and the fact that he spent so much time messing with the tune and never got it to run well makes me feel like there is something else going on.
Some of your mods are somewhat out of the norm. Reverting to a configuration that typical rotary folks can relate to may help with troubleshooting.
While I'm willing to do whatever it takes to get my car running, I will say I'm hesitant to replace more parts--I've spent thousands on parts and labor over the last few years so it sounds a bit painful to "go back". But again, if that's what it takes, I'll do it. Most of the oddball parts like the custom CAS and coil setup are things Don was doing in relation to the AEM to have a stronger more reliable setup, and to make the AEM I have compatible with the FC.
