Finally got my BHR ignition upgrade!
Postby GR-8 » Fri Jun 05, 2009 9:14
So I ordered this last week and a week later I got it. Was waiting all day. This was the only good news to come to me for the 8 today.
Well install went quite smooth. With my K&N V2 SRI I didn't have much to remove. (I left it in tact) I had enough room to reach in un-bolt the old ignition coils. The most difficult part of teh whole process would be hunting for dropped bolts. One of the 4 that hold the new ignition coil bracket on got lost for good. :(
Uhhh word of wisdom. Don't attempt this just after driving the car around a while. You are working near the throttle body and your hand will come in contact with it. My hands are severly burnt. Yes they are. (Ok not severly but pretty damn good)
3 outta the 4 stock coils had burn marks on them and well 2 of those 3 had sever burn marks on them. The stock bracket which the new bracket hovers over with spacers is competely toast. lots of coloration on it from heat.
Overall the car runs way better upon first start up. Low end I don't get hesitation and up high it's smoother than ever. Idleing at a stop light is great. no more rough idle and needle jumping cause the 8 is trying to keep from dying. I bet I have a clogged cat..... so in the future I may skip that CF hood I want and go catless.
wyosaint
Postby wyosaint » Fri Jun 05, 2009 9:14
nice, congrats!
Postby TheNewBlack » Fri Jun 05, 2009 9:14
Awesome! Glad the car is running smoother now.
TheNewBlack wrote:Awesome! Glad the car is running smoother now.
Smoother yet still grinding second.
Thanks Y'all. I'm glad. Big difference. I'm lookig forward to have a Dyno day at SR Tuning again to see if there is any difference in power anywhere. The but dyno sure feels it.
*DarthRX8*
Postby *DarthRX8* » Fri Jun 05, 2009 9:14
Welcome to the club and congrats!
Postby Huzer » Sat Jun 06, 2009 9:14
Congrats on FINALLY getting those on there! One of my favorite mods for the car.
lancer
Postby lancer » Sun Jun 07, 2009 9:14
Greek8 wrote:So I ordered this last week and a week later I got it. Was waiting all day. This was the only good news to come to me for the 8 today.
is it hard to install, Im waiting for the new Coil to arrive too, but i need some one to help or show me install it. can you show me how to do it.?
Postby GR-8 » Sun Jun 07, 2009 9:14
lancer wrote:is it hard to install, Im waiting for the new Coil to arrive too, but i need some one to help or show me install it. can you show me how to do it.?
It was very easy to install. Do you have the stock airbox or aftermarket intake?
With my aftermarket intake I was able to skip several steps and didn't have to touch it at all.
Postby chickenwafer » Sun Jun 07, 2009 9:14
Do you have an AP so you can change your dwell settings? That's the key for getting the most power out of those coils.
I build my own setup and it misfired massively on stock dwell, but that was at much higher power levels than NA. I do know there is power to gain with the proper dwell tho.
chickenwafer wrote:Do you have an AP so you can change your dwell settings? That's the key for getting the most power out of those coils.
Sadly I do not. I used to but there is a story behind that.
What happened? Did it brick your pcm or something?
chickenwafer wrote:What happened? Did it brick your pcm or something?
No but something occured.
*DarthRX8*
Postby *DarthRX8* » Mon Jun 08, 2009 9:14
according to my AP dyno I gained about 6 whp and 10 wtq (which of course means nothing since it was the AP dyno). It also could have been the tune that came with the dwell changes. Never the less it went up which is always a good sign.
Since you don't have an AP maybe a local shop could hook you up?
Postby GR-8 » Mon Jun 08, 2009 9:14
*DarthRX8* wrote:according to my AP dyno I gained about 6 whp and 10 wtq (which of course means nothing since it was the AP dyno). It also could have been the tune that came with the dwell changes. Never the less it went up which is always a good sign.
I do have a free dyno pull that I won at the BBQ..... That would be nice but it really wouldn't help me see a difference because it's most likely a different dyno than the one we had at the Dyno Day.
I can't wait till we have a dyno day back at SR tunning.
Postby RX-7 Chris » Tue Jun 09, 2009 9:14
About time
Users browsing this forum: No registered users and 126 guests
