Dream Mods
Postby RX-7 Chris » Mon Nov 05, 2007 9:14
I hope to have these mods in the next year or two.
Camden Superchargers http://www.camdensuperchargers.com/index.php?pag=402
1979-1985 Holley 650 Seven Inch Supercharger Kit includes:
Seven Inch Supercharger 2395.00
1986 - 1988 Waterpump housing 85.00
1986 - 1988 Waterpump 65.00
Holley 650 Carburetor 450.00
Universal Throttle Bracket 39.95
Air Filter 32.95
Holley 650 Carburetor Gas Line w/ fuel pressure gauge 51.95
The superchargers produce between 6 and 11 pounds of boost
At 6.5 lb. of boost you can conservatively expect 35-50% increase in Hp. You will feel the boost as low as 1500 rpm's as the supercharger is making power, and torque at a lower rpm due to the fact that the Supercharger spools up faster than a turbo. When shifting gears you will not lose your boost.
$3119.85
[attachment=82:7inchkit_2.jpg]
Postby MazdaTom » Mon Nov 05, 2007 9:14
Start saving those pennies!
Postby Colombia28 » Mon Nov 05, 2007 9:14
That would be sweet!
Re-Speed
http://www.mrcmfg.com/respeed/catalog/prod...e067ddb6ba4c520
1978-1985 Rx7, Stage II Rack/Pinion Conversion $775.00
Kit Features:
Adjustable lower control arm pivot points
Urethane lower "A" arm bushings
Urethane engine mounting. (Aluminum engine mounting option)
99% bolt in. Mounts without modification to the chassis.
Designed to fit both 12A and 13B engines.
Flaming River brand steering u joints
Does not hinder the operation of the collapsibility of the stock steering shaft
Added angle designed into the lower steering linkage for 2 more points of collapsibility.
Available quick ratio rack that will transform the vehicle into a pleasure to drive.
Uses stock outer tie rods (Rod End Tie Rod Kit Option).
Postby tsx_guy » Mon Nov 05, 2007 9:14
they make this for the 6? this is what I want? a sc....a little more power/torque at the lowend, but still daily drivable.
