Rear End Gearing?
I've been looking for this all last night. I read in a few forums that it's 4.44. Is this right? Is this also called the Final drive. I'm thinkin that one day, not anytime soon I want to change the rear end gearing. I've found to company's that sell 4.77 for the 8, FEED and I forgot the other one. Would this make a difference in quarter time at all? There was an Australian forum and one guy said that he's putting in 4.90.
arctic_blue83
Yes, rear end gears in a RWD car are called Final Drive Ratio gears. Yes, they will change the way your car accelerates. If you go with a shorter (numerically higher) FD (final drive), your car will accelerate faster, however, it doesn't necessarily mean it will be much faster in the 1/4 mile.... the reason for this being it *might* necessitate an additional shift at the end of the track, which would obviously be counter-productive to your ET.
Now a couple of things to keep in mind, the first being ALL of your gears will be "shorter" with a numerically higher FD, meaning, hypothetically if your car redlines at 33mph (I don't know where an RX-8 redlines, this is just hypothetical) in 1st gear, with a shorter FD, in 1st gear your car might now redline at 30mph.... see what I'm saying? Have you ever noticed that your car accelerates faster in 1st than in 2nd? Faster in 2nd than 3rd? Ect ect, suffice to say, the shorter the gear, the faster you accelerate due to torque multiplication. Lower gears are "shorter" than higher gears, that's the simplest way I can put it lol.
One thing I do know.... I tend to take an in depth look at a variety of different sports cars (I'm a member of about 25 forums or so lol), and I know in the S2000 crowd, some of those guys have went from a 4.10 FD (stock) to a 4.57 FD IIRC, and have cut off a half a second off their 1/4 mile times.... which is pretty big IMO.
There are a few downsides to be aware of when switching your FD:
1. Might need an extra shift in the 1/4 mile.
2. Your speed-o might not read correctly without some sort of correction device, depending on how Mazda set it up.
3. Your MPG on the highway will most likely go down, as your motor will be spinning at a higher RPM.
4. Even if the gears are inexpensive, they will likely not be cheap to have them installed.
5. Your "theoretical" top speed would go down, but then again, the RX-8 doesn't have the power to access redline in 6th gear, so you shouldn't worry about it too much.
This is a very technical install, that I would not recommend doing yourself, unless you're extremely knowledgeable and have the proper tools. Typically, the S2000 guys end up paying around $1000 for the price of the gears & install. Good luck, and happy modding.
Very helpful. I like you eventhough your always putting me down. J/K. If and when I ever do this my bro has a rear end specialist that has built his rear end in the vette and olds. H'ed be up for the challenge. It may also help. When I reach the end of the quarter, I always shift in to fourth just before I pass the sensors. Maybe hitting fourth earlier would be better? Or a better launch? I only imagine that launching would be even harder with the 4.77 gearing.
I always wished that my 3rd gear went through faster. The RPM drop from 2nd to 3rd is larger than from 1st to 2nd. Maybe getting 3rd reageard is an option. I read once along many many months ago that the Jap 8 has a better gearing for 3rd than the U.S. model and their quarter times are better cause of it.
Half second off quarter time for a just gearing is great. What else gives you that for under $1000. The 4.77 gearing costs $300 for the 8 and whatever install is going to cost.
arctic_blue83
According to this gearing calculator:
http://www.turnzero.com/technical_resource...gear_calculator
I input specs I found online for a RX-8, here's what it should do to your car's top MPH in every gear, here's stock:
Here's with a 4.77 FD:
Here's with 4.90 FD:
Obviously you can see the effect it will have in every gear, although your 1/4 mile ET will be more dependent on what gear you're currently finishing the 1/4 mile in, compared to what gear you would be finishing the 1/4 mile with a shorter FD. If you will still be finishing the 1/4 mile in the same gear, you can bet it will be a decent bit faster with a shorter FD, again provided there's no extra shift.
On another note, for a car with a 9000rpm redline, the RX-8 has fairly tall gears... I don't know too many sports cars that 2nd gear goes almost to 70mph.... I'm assuming they kept the gears a bit on the taller side just to help out with gas mileage.
arctic_blue83
<div class='quotetop'>QUOTE (Greek8 @ Oct 28 2007, 03:37 PM) [url=index.php?act=findpost&pid=8529]<{POST_SNAPBACK}>[/url]</div>
Actually, if you're already shifting into 4th, I would almost guarantee your ET will go down, and your trap speeds should go up. This would be a worth while mod for you IMO. Also, because the RX-8's peak torque at such a high RPM (around 7k iirc), a shorter 1st gear in theory should make launching a tad bit easier, as you'll get into your powerband much faster from a stop.
From what I've seen on dyno's, RX-8's typically make peak power right around 8500rpm, so you'll want to shift right around that RPM, maybe a little bit higher in 1st to take advantage of 1st gear's gearing advantage. The general rule of thumb is to shift at peak power, as long as it doesn't drop you below peak torque in your next gear. If I owned an RX-8, in first I would go to 9000rpm, then probably shift close to that in every other gear, maybe around 8800rpm as power doesn't seem to drop that bad above 8500rpm in those cars, so might as well keep shifting high.
On another note, I don't like to think I ever "put you down" per se lol, I think of it more like "teaching/helping you" lol!
Half second off quarter time for a just gearing is great. What else gives you that for under $1000. The 4.77 gearing costs $300 for the 8 and whatever install is going to cost.[/b]
That's what I see it as. Help and Learning. Sometimes I see that STI in your avatar and I read the post the wrong way but I learn alot from your posts. Thanks for all the info. Your like a library filled with useful information, only I don't have to search for it. I just ask a question and wait for a post. I apreciate all the research you put in for everyone to get the information too.
thanks. [img]http://coloradomazdaclub.com/forums/style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
I usually always shift at 9k rpm in first and at 8500 at second. Were you wathcing me.
What is your opinion on re-gearing third gear only. Would it be worth it. I'll try and find what third is in the Jap market and the U.S. market.
arctic_blue83
<div class='quotetop'>QUOTE (Greek8 @ Oct 28 2007, 04:00 PM) [url=index.php?act=findpost&pid=8540]<{POST_SNAPBACK}>[/url]</div>
LOL, not a problem.
Just to show you what I mean about the RX-8 having tall gears, here's gearing from an STI:
^^^Notice how short they are, shifting at redline, I can only get to 56mph in 2nd, and STI's make peak power around 5500-6000rpm, so really, I only go to about 50mph in 2nd.
Here's another graph, with gearing from a Mazdaspeed 3/6, although they have 2 Final Drive ratios (don't ask lol), so there's 2 graphs:
^^^Notice how much shorter both the STI & Mazdaspeed's gears are, this was done in order to squeeze as much performance/acceleration as possible out of them. Although there comes a point when gearing is "too short", which is when either it 1)requires too many shifts, or 2)on a street car, it lowers fuel economy too much. Which is why Mazda went with a 2nd FD ratio just for 5th & 6th gears on the Mazdaspeeds, as they have a taller FD to help out a bit with fuel economy on the freeway.
I never realized how tall RX-8 gears are... just looking at them, if not for gas mileage, I can't think of another reason why Mazda would make such tall gears on the 8, as they're obviously leaving a good bit of performance on the table. If I had an RX-8, and didn't mind the gas mileage drop, I would probably go with the 4.90's.... but that's up to you. Even the 4.77 would be extremely helpful, especially if you're already shifting into 4th in the 1/4 mile anyway, those gears would actually make 4th more usable lol.
thanks. [img]http://coloradomazdaclub.com/forums/style_emoticons/<#EMO_DIR#>/biggrin.gif[/img][/b]
LOL, not a problem.
arctic_blue83
Well, it looks like you already know where to shift, although if you wanted, you could shift a couple hundred RPMs higher in 2nd and above, maybe around 8700-8800. I don't know about the difference in the USDM 3rd vs JDM 3rd gears, but I can tell you one thing, rather than just swapping gears in your rear diff, replacing 3rd gear would mean tearing apart your entire transmission which would be A LOT MORE EXPENSIVE! I would bet your labor bill would more than double... it's cheaper to just go with rear end gears.
What is your opinion on re-gearing third gear only. Would it be worth it. I'll try and find what third is in the Jap market and the U.S. market.[/b]
arctic_blue83
On another note, notice the gearing for the Mazdaspeed cars and the STI... these are both cars with what is considered extremely short/close ratio gears. This actually isn't all that common, typically what a lot of manufacturers do is making 2nd gear top out right around 60-62mph.... can anyone guess why? That's right, in order to give cars a good 0-60mph time in stupid magazines, to help sell cars lol. Cars like the Mazdaspeeds & STI are penalized in that category as they require an extra shift to 3rd to reach 60mph. On a road course/autoX, I would rather have shorter gears as 0-60 times I could care less about.... but then again, I'm not a manufacturer, so I'm not worried about selling cars based off of 0-60 times.
This is another reason why I've always said comparing 0-60mph times is retards *cough*FreeZing Cx7*cough*, as it doesn't always show the cars true potential based on gearing. I prefer to ask what the car's 1/4 mile is, and more importantly, at what trap speed? As trap speeds will more accurately tell the tale of how fast a car is.
arctic_blue83
<div class='quotetop'>QUOTE (Greek8 @ Oct 28 2007, 04:29 PM) [url=index.php?act=findpost&pid=8543]<{POST_SNAPBACK}>[/url]</div>
I'm sure you could find one if you searching online long enough, although another way to trick the calculator I posted a link to above would be just keep lowering the redline in the calculator until 6th gear maxes out right around 65mph lol.
I edited my last post while you were replying. I was wondering. Is there some calculator that would give me rpm speed in 6th running at 65 mph?[/b]
arctic_blue83
arctic_blue83
<div class='quotetop'>QUOTE (Greek8 @ Oct 28 2007, 04:40 PM) [url=index.php?act=findpost&pid=8546]<{POST_SNAPBACK}>[/url]</div>
Around town, sure you could use 4th instead of 3rd to help out a bit. If you really don't give a damn about gas mileage, and you're already shifting into 4th in the 1/4 mile, I would just go with the 4.90's, as it looks like you would have to be trapping at 119mph in order to have to shift into 5th, which even turbo'd probably isn't going to come close to happening lol.
Oh ya. I forgot to mention, I could just drive in 4th instead of 3rd for gas mileage? I really don't care I just want a faster 8 with stock motor hopefuly FI sometime.[/b]
<div class='quotetop'>QUOTE (arctic_blue83 @ Oct 28 2007, 05:45 PM) [url=index.php?act=findpost&pid=8548]<{POST_SNAPBACK}>[/url]</div>
Wow that's like dead right for the stock 6th gear. I am scared to ask how you did that because the answer will be so simple that I will feel stupid. If that's all the change in RPM I think I should still be ok on highway gas mileage.
Thanks
I'll save you the trouble, stock (4.44 FD) it looks like you'll be spinning about 3150rpm at 65mph in 6th gear. Sound about right?
With a 4.77 FD it looks like you'll be spinning around 3400rpm at 65mph in 6th gear.
With a 4.90 FD it looks like you'll be spinning around 3500rpm at 65mph in 6th gear.[/b]
Thanks
