So everything above was more of a recap from what i posted on
http://www.rotarycarclub.com.
Here is the current plan i have in motion. Once i get moved to Colorado here in the next two weeks, the car is going to be on hold til i can get it out with me. Would be nice to get it to run (to add the chance of me driving it to colorado instead of shipping it)
also, the RE Speed brake kit came in yesterday
[color="Red"]To Do List (This is more for my own use since i loss crap like this)[/color]
PHASE 1 - Getting the car running!A. Fix coolant leak issues (have to verify with the engine running)
B. Finish exhaust
C. Install RE Speed Kit for front brakes.
D. Need lug nuts for vert wheels
E. Install shocks in rear once second shock (finally) arrives.
F. Tighten all suspension bolts in rear.
G. Need new batt. Temp. use of old miata may work pending start issue.
H. Fix start "not cranking" issue.
I. Add ground cabling here and there.
J. Install pass. side Isuzu seat.
K. acquire and install E-Fan.
PHASE 2 - 12a Fuel Injection ConversionA. Acquire throttle body assembly (Tmw vs. Fuji)
B. Finish mega squirt and harness.
C. install intake manifold and throttle body.
D. Need two fuel injectors (550 vs 680)
E. Acquire and install fuel pump.
F. Install fuel pressure regulator
G. Run fun feed and return lines.
H. Tune!
PHASE 3 - More Power! 13B 4-Port N/AA. acquire s5 rotor 9.7:1 rotors
B. acquire rx8 e-shaft
C. acquire automatic rear counterweight
D. have rotating assembly balanced
E. Port 12a irons
F. Cooling mod GSLSE housings / 12a irons
G. Acquire apex seals of choice (low wear?)
H. Need four fuel injectors (about 460?)
I. Assemble engine. (skipping details for now)
J. Acquire 13b manifold
K. Retune with mega squirt.
Also, i added this little toy.
