Car Electrical Issue...
christi
Postby christi » Fri Jun 24, 2011 9:14
Yeah.... Mazda was gonna charge me 300$+ to diagnose and fix it.
Although, the oil pan is technically on don's part. When they replaced everything, there was no seal... Although I'm not going to just rant on him.
The car is working now. My buddy disabled the stupid buzzer. We verified that there's plenty of oil, not low, either. So.. now I have to manually see how much oil I have roughly each fill-up. .. that stupid light is gonna bug me though.
Pat, there's actually not a connector for that wire.... Pat #2 looked at it.. there was one connector that we thought was for the wire, but... it's plugged up and not working haha.
Pretty much my car is a mess with the harness/electrical aspect... once I come up with the money, I'm gonna have it re-wire anyway.
But.. for now she's working, and alive... thanks to those that helped (here and in person)... much appreciated.
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
alex_n/a
Postby alex_n/a » Fri Jun 24, 2011 9:14
I think the oil level sensor is located next to the oil pressure sender. Look at the last picture I posted and you will see a black wire plugged into the engine. but I may be wrong, so if someone could agree/disagree that would be great.
Postby RX-7 Chris » Fri Jun 24, 2011 9:14
oil level sensor is in the oil pan.
Postby iani1.1 » Sat Jun 25, 2011 9:14
its the plug bottom left from the engine mount on the left side of the car
christi
Postby christi » Sat Jun 25, 2011 9:14
A few pages back someone said the wire hanging down was the oil level sensor. However if it's inside the pan Midas said they reconnected the one wire they disconnected changing the oil pan gasket.
I disconnected the buzzer but the oil level light is still on of course. The car is definitely not leaking anymore and is full as well as the 2-cycle can I have installed in the engine bay. So I'll just manually watch the oil fOr now on. However shouldn't Midas be better at it and check to be sure they reco nected it even though that'll cost another oil change technically?
Sent from my iPhone.
13B n/a Street Port
Goopy performance
2005 Mazda 3
D Walker
Postby D Walker » Mon Jun 27, 2011 9:14
Personally, I would not let Midas check over any car beyond maybe the brakes and exhuast, which is what they are good at and are trained for, but thats just me.
Postby RX-7 Chris » Mon Jun 27, 2011 9:14
There are 2 sensors on the side of the oil pan on my car and I think it's still the same in '90. Take a look at the oil pan just below the spark plugs and see if there are two sensors. I'll take a look in the FSM later.
D Walker
I just read back through and noticed a couple of things-
first- are you saying Midas pulled the pan and resealed it? Because thats a little scary on a couple of levels. If you dont know what your doing you can and will damage the oil level sensor. Also that pan was (I believe) sealed with Three Bond, which is an extremely strong gasketing compound, so I really doubt if it was leaking there, but things do happen.
Oil leaks are a strange thing, becuase oil flows around pretty much everything and many times what you think is leaking is not, but something above or around it is leaking instead, especially oil pans. Obviously I never saw the leak, but do tend to go with Chris and suspect the oil lines, the amount of oil you are talking about loosing is more what you would see from a high pressure source that anything else, and if the line was loose or one of the aluminum seals bad (you DID use new ones on install correct?) then you will have a very good leak in no time. A simple tightening or replacing of those seals would have fixed the issue.
Anywho- the important question here is how low you ran the motor on oil and how many times? Because rotaries do not like to be run low on oil, and bearing damage will occur.
The reason I thought it was the oil lines and not the pan is because the oil lines are under pressure and the pan just has oil sitting in it.
christi
Postby christi » Mon Jun 27, 2011 9:14
Chris- I'll check again, but I swear I didn't see anywhere that wire could hook up.
Don- the car is not leaking anymore. When I texted you, and also posted here a few pages back, the area that I took my photos was the area that it was leaking. I could feel where the oil was leaking at. The lines were clean, and yes everything that was installed after we got the motor was *new*. The car is no longer leaking, except for that buzzer I disabled, and I check the oil everytime, before I start the car. Also, there's no more leak...
It didn't get as low as I imagined. It was also dark when I thought it was low. Maybe half. I understand these cars (like any) cannot run on low oil.
13B n/a Street Port
Goopy performance
2005 Mazda 3
SecondGenPAt
Postby SecondGenPAt » Mon Jun 27, 2011 9:14
did you or pat ever run a catch can line to the pcv port on the oil filler tube (like the seafoam can on mine?)
Just thinking of this now as I remember the oil spill we had on the first oil fill.
christi
There was a first oil spill? Was I not there? Haha. No, I don't believe we did.
Also, More issues arise! It'll never end haha! Alignment issues ftl :/ but the car runs!
13B n/a Street Port
Goopy performance
2005 Mazda 3
