This is from today. Ignore wire. It's from the acv/smog pump that I no longer have.
http://yfrog.com/hs3fvykj
^ today
http://yfrog.com/kgw4isj
^ yesterday
Car Electrical Issue...
With that much oil, I'd look at the oil cooler and lines. It might be leaking out around the crush washers. Were new crush washers installed on the oil lines?
I still need to get $5 from you for the block off plate, lol.
christi
Yep. I have your 5$ on Friday. I haven't forgot trust me.
New lines new washers. If the oil cooler, doesn't that mean the frame needs to be dropped or engine pulled...?
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
13B n/a Street Port
Goopy performance
2005 Mazda 3
Depends on where it's leaking from. With that much oil, it should be really easy to spot the source. Without knowing what part of the motor it's coming from I couldn't tell you.
Look at the oil filter pedestal as well. You could also have a cracked oil cooler caused by over tightening.
christi
Yeah. Don had put everything on as far as I know and we just dropped the motor in. I have cardboard that I can slide under there tonight and verify where it's leaking by that and show up a photo tomorrow morning.
Tyler may not have jacks to borrow. Is there someone I can borrow your jack and stands Friday to verify even better ?
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
The best way to find the leak is with the car running and the hood open. Once the car is warmed up you should see where it's coming from. The oil cooler would have been hooked up after the motor was installed.
I'm going to be working on my car this weekend so I need the jack and stands, sorry.
christi
Oh well. Then I'm mistaken. I don't know these things. The motor was installed before I got home. My bad.
Yeah, that's why I said someone :P
...alright. I'll verify this Friday afternoon when all my other errands are completed.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Ok, I found partial oil leak on the "right" side of the motor. I took what I could tonight to kinda explain what's going on. The OMP lines and OMP are *not* leaking. I checked that, and no oil was to be found. The dipstick is *full*. I had to put in 2 qts of oil yesterday as while driving home, it read that I was an INCH from 30 oil PSI while in 5th gear; and down shifting to 4th or 3rd, it would go between 30 and 60 PSI then dip back down. The car wasn't as empty as I thought yesterday, as I had 1/2 quart remaining. When I went to walmart to purchase 4 quarts of oil and by the time I got home, there was a semi-large puddle of oil on the ground. .. which leads to today.
Pictures below:
*closer view*
*oil that leaked from last night until tonight*
I'm going to work on her Friday after I have a docs appt and a appt with my Mazda 3 to get the vibration to stop. I'll turn her on as suggested, and try to see where exactly it's leaking from. But this is just as a *stand still* until then.
I have a few more photos to show of the spark plug area, and possible up underneathe where the leaky part is if I can get my camera under there correctly & what the oil actually looks like... or something for a better idea.
Pictures below:
*closer view*
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
It doesn't appear to be from the front of the engine, it could be the oil cooler line closest to the firewall. or the oil filter, or perhaps it can also be from the p/s lines, but I thought its the p/s.
christi
What i could get for the most part of putting the camera allll the way under the car and "feeling" lucky of taking the shot.
I realize she doesn't have a skid plate. She never had one....
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Can't be P/S. I know my P/S pump leaks as it is. But this is actual Oil. The Oil pressure gauge last night dipped down to a INCH from the 30 PSI marking. When I parked her yesterday *after* I got home from work (around 9PM).. I went and filled 1QT of oil, as, it appeared to be emptied on the dipstick @ 9PM. I go to walmart (about 20 mins total rd trip), purchase 4QTs of oil, use one extra... and this morning a MONSTER of oil puddle underneathe... seeing as the pics. The dipstick still at the Full line.
It appears when the car is not on, the oil doesn't have the amount of pressure as if on, so it drops a *little bit*.. of course, but when driving it, it seems to lose a lot quite a bit, but I haven't verified how much due to my current situation when I get home from work.. Hence why I'm looking at it on Friday afternoon.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
NOTE: I was told that the wire hanging down was part of the emissions that have been removed, was I wrong?
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Ok.. I'll check the plug and also re-plug up the oil sender level or whatever that wire is called back up on Friday. I'll have better time to do so, anyway.
and.. thanks for your help guys.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
yeah, (post #54 2nd picture) oil drain plug doesn't look fully tighten. but I also notice a large amount of oil under the sub frame, so if I were you I would double check everything is torque down to spec. Don't just take other people's word.
