Thanks chris!
Ian: I got Saturday off. I am working Friday though. So saturday and Sunday will work. I need to get a bigger and better battery and a new starter....I want to move the car to my house if I can.
Car Electrical Issue...
christi
Pat does. Or does it have to be a specific timing light for rotaries or does it matter?
And what time Saturday?
So I want to understand a bit better:
Once I can time her, drive her for the X miles, she may actually run better no?
But it doesn't explain why she hardly starts. I guess we will find out Sunday.
Oh, how much do you want for your trailing coil?...if anything
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
13B n/a Street Port
Goopy performance
2005 Mazda 3
a coil powered light works best.
once its timed we'll be a step closer to finding the problem or problems. im going by process of elimination and taking the more simple approach. i cant promise that itll be running correctly after i fix the timing but im most certain that timing and the coils have a big part in this.
i still have to find the coil if i have it or not. im sure i do but ill bring it on sunday afternoon or whatever.
If your coolant temp sensor is not plugged in it will have serious issues. It will run rich and the ecu will get pissy.
A wideband is not nec on an N/A car (obviously nice to have) but honestly even a narrowband is good enough as long as its working for an NA car, esp with as blunt a tool as an AFC.
RTEK is not really a standlone, it is a piggyback board dropped into the stock ECU that allows some interface with the stock ECU chip. If your going to have a piggyback, might as well be one that is simple and easy to deal with. Not that I care either way, because IMHO the best thing to do is drop an AEM ECU in it and call it a day.
I realize that none of my advice is being followed here, but I will say it one more time-
> Make sure all the wires are plugged in. Go over this multiple times and do not assume it was done correctly.
> Time the car. This is covered in the FSM in detail and in several online tutorial sort of things
> Check the grounds- loose or disconnected grounds are teh debil
> Check for vacumn leaks. again, even if everyone think its been done, do it again.
> go to rotary ressurections site and MAKE SURE the S5 emissions delete was done properly. If even one thing is not done right, the car will be completely wonky and the ECU will be pretty much permenantly pissed off
> Check for broken grounds. Not sure if I have covered this, but bad grounds are literally 99% of the issues seen in older cars with ECU's highly dependant on proper grounding.
> Check the ECU for codes. This is covered in the FSM. Fix whatever is pissing the ECU off
Also please remember that until you lean the car out, its not going to run well at all., timed or not.
Made sure you download these:
http://foxed.ca/rx7manual/manuals/1989FSM/
http://foxed.ca/rx7manual/manuals/S5wiring.pdf
http://foxed.ca/rx7manual/manuals/tech/1990%20RX7%20TECHNICAL%20DATA.pdf
http://foxed.ca/rx7manual/manuals/parts_manuals/89-90/
They will really help you with getting you car going.
christi
Don, been listening. I'm just stupid in mechanical ways to do this myself without eff'ing up.
Chris, thanks they've been downloaded.
Ian, what time Sunday an where we meeting up?
Sorry for short answer but I'm in a area where I have crappy reception.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Okay. We fixed it. Car runs and stays idled. Time to put miles on her in time for the cruise in July and the BBQ. The AiT sensor and engine temp sensor fixed the issues it was having. Thr tach works and everything else pretty good.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
that's greaaaat. do you feel a noticeable power difference from before you had it rebuilt? and what is your next supporting mod? check this thread out on 7club, it's a 230rwhp street ported n/a.
http://www.rx7club.com/showthread.php?t=818133
christi
alex- Because Secondgenpat had removed the 6-port butterfly values (since all emissions gone), my low-end torque is gone... but my high-end torque is there. All the power i see is above 6k RPM. For the majority of me driving her is below 4K RPM. So far I put 40miles on her since the rebuild.
Since my other car is having horrible vibrating again, I am going to drive the 7 for the rest of the week, and I have a appt at a alignment shop to get her aligned and looked at why she's vibrating between 60-70mph. It could be a bent wheel or it could be something else. Ugh.
Either way, car runs. I'm one happy camper. It's changed my whole aspect around on my mood lately
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
I wouldn't recommend red lining it till the motor is broke-in.
christi
Yep. I did that once. Otherwise it's been 4K RPMs and below.
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
christi
Technically it was 6k rpm otherwise it's always at 3-4k shifting.
I've got a mystious oil leak. I hope to be able to snoop
Around sometime Friday and find out where. Blah. The drive today was pretty good. The oil leak happened sometime in the evening when I noticed it. So I'm not sure. I'll update more later in the week to see what's happening
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
what side of the motor is the oil leak?
christi
From what I can see it's kinda towards the back. When I look inside the engine bay it's more leaking up front it seems as there's wet/puddle of leaking. The OMP is not wet or covered in oil. The oil lines are not cracked and they are pinched correctly. So I'm not sure. I don't have a way to look at it until Friday night when Tyler ones by as he is dropping his wheels off
13B n/a Street Port
Goopy performance
2005 Mazda 3
13B n/a Street Port
Goopy performance
2005 Mazda 3
