Fixer upers - car almost "good" to go
Postby iani1.1 » Tue Mar 01, 2011 9:14
yea its easier for the s5 the s4 you have to build a box
christi
Postby christi » Wed Mar 02, 2011 9:14
That's so silly though! Ahh.. Well, I think we can get the code read not this weekend but next, unless Jimmy feels like driving to the springs :P
13B n/a Street Port
Goopy performance
2005 Mazda 3
nothin' but stock love.
christi
Postby christi » Sat Mar 26, 2011 9:14
So...I just wanna say that my car is still running strong even after she overheated yesterday due to a massive coolant leak that is now fixed. I still have to check the levels though, just in case. I also had my aluminum intake made while I got everything else worked on, and my K&N filter installed. She's free of the rats nest! Now to get the rest of the system installed and she's nearly good to go.
Just as a future precation - if my motor blows, where can I find a good place to ordr a JDM spec TII motor, street ported?
Sent from my iPhone.
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby chickenwafer » Sat Mar 26, 2011 9:14
The only place you will find a street ported engine will be from an engine builder, in which case it being JDM doesn't matter. Typically the JDM engines are stock Mazda kegs sold on eBay pulled from Japanese cars, meaning a stock port. Most of the time, the motor being JDM does nothing for performance anyways, they are pretty much the same.
Postby iani1.1 » Sat Mar 26, 2011 9:14
japan2la on 7club. he aint cheap though but quality is there. mine came with the dual alt pulley, hks downpipe and a greddy type s.
christi
Postby christi » Wed Mar 30, 2011 9:14
Ian, you said you wanted my hood. I'll verify if it's aluminum for ya tomorrow. Also, anyone know where I can find a afm that's in working order? Mine doesn't work and trying to clean it failed miserably.
Also...talking with Eric breifly on text - how do I fix my idle I'm the 7? She idles exactly at 100RPM! Or dies if I do not keep gas on. I was told a few years ago , to fix the idle is by TPS, but Eric said don't touch. So anyone willing to help me fix his weekend ?!
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby RX-7 Chris » Wed Mar 30, 2011 9:14
I can probably take a look at it this weekend.
christi
Awesome. I'm
Happy to drive there or give you my address. I'm off Saturday and Sunday, which would work best for you ?
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby RX-7 Chris » Thu Mar 31, 2011 9:14
Saturday would work for me. It would probably be best for me if you came my way.
christi
Postby christi » Thu Mar 31, 2011 9:14
PM sent.
13B n/a Street Port
Goopy performance
2005 Mazda 3
Postby iani1.1 » Thu Mar 31, 2011 9:14
christi wrote:Also...talking with Eric breifly on text - how do I fix my idle I'm the 7? She idles exactly at 100RPM! Or dies if I do not keep gas on. I was told a few years ago , to fix the idle is by TPS, but Eric said don't touch. So anyone willing to help me fix his weekend ?!
adjust the idle screw on top of the uim. the lower you go the higher the idle and vice versa
christi
Postby christi » Sun Apr 03, 2011 9:14
So yeah. We adjusted that Ian... Worked up until I drove home (chris lives about 15-20 minutes from my place). I parked it, and she didn't want to keep an idle. I also wanted to recorrect myself, She was idiling at 500RPM... When we fixed it, we got her to 750RPM. However, the screw is all the way lifted up.
Chris found an interesting part of my problem probably why I'm having so many issues. So my AFM may not be broken for the one by the filter; but the one on the back of the engine up top of the UIM?.. or something is not attached to anything. This could be the reason why the Code 10 for the thermosensor is showing up on the scanner back when I got Mazda to look at it. I just can't find any parts for that, and I know Mazda is going to rape me a new hole if I order through them.
I also need to make a block-off plate for the hole where the Smog pump used to be, and as soon as I come back from FL with my Header, I'll have the exhaust leak fixed. So all in all, thanks to Chris... I found one of the major issues that is causing my RX-7 to behave the way it does... thanks, man! :P
Oh, and not only fixing the t-stat and o-ring on the car, I now have a leak for the water pump. Hoping to fix it next week :)
13B n/a Street Port
Goopy performance
2005 Mazda 3
Users browsing this forum: Bing [Bot] and 73 guests
