Another FD in the area
Re: Another FD in the area
Postby speedjunkie » Tue Jun 16, 2015 9:14
I'm at work every day. I'll message you my number on facebook so you can call and I can come to the gate and get it from you. You know which building I'm in, right?
I think I had the same issue with a drain flange before.
JTurton7
Postby JTurton7 » Tue Jul 21, 2015 9:14
finally done with oil catch can lines I think, just waiting on the fire-sleeve to show up for it.
Postby speedjunkie » Tue Jul 21, 2015 9:14
Damn, I never thought of doing it like that.
Do you have any of that line left? Where did you get it? What size is it? I want to make a hardline to extend from the one that came with the kit over to the can instead of using the vacuum line that came with it.
JTurton7
Postby JTurton7 » Tue Aug 11, 2015 9:14
speedjunkie wrote:Damn, I never thought of doing it like that.
Should have just called or texted me man! Yeah I got like 8ish feet left and your flare tool. Its -10 hardline.
Postby speedjunkie » Tue Aug 11, 2015 9:14
Well I still don't have the car yet so it's no big deal lol. And I forgot you had the flare tool lol. I'll hit you up when I get back with it next month. Although I'm not sure my current hardline is -10, might be closer to -8, I'll see next month. Thanks!
JTurton7
Postby JTurton7 » Sun Aug 16, 2015 9:14
I did a thing. UIM stays a lot cooler.
Postby speedjunkie » Sun Aug 16, 2015 9:14
Have you tested it with an IR thermometer or anything? I'm sure it helps, anything would, I'm just curious how much it helps. I've been planning on doing a thing of the same order.
JTurton7
my highly scientific methods were as follows:
Before: Too hot to touch.
After: I can touch the uim or lim and it doesn't hurt.
If you have an IR thermometer we can do some tests
LMAO, that actually says a lot. I do believe I have an IR thermometer. However, how easy is it to take off the heat shield?
If I don't have one, I know we have one at work lol.
JTurton7
It's super easy to take off. These 3 bolts then it comes right out.
We can do this. And I think I'll copy yours almost exactly lol.
JTurton7
Postby JTurton7 » Mon Aug 17, 2015 9:14
On yours I would extend it lower behind the turbo to shield off more of the turbo manifold. I was limited by the small size of the cheap piece of metal from lowes. Ill call it good enough for like 14 bucks and DEI cool tape I had already.
Postby speedjunkie » Mon Aug 17, 2015 9:14
JTurton7 wrote:On yours I would extend it lower behind the turbo to shield off more of the turbo manifold. I was limited by the small size of the cheap piece of metal from lowes. Ill call it good enough for like 14 bucks and DEI cool tape I had already.
I'll try to cover as much as possible, but I'd also like to run the hard line for the wastegates behind it, so that will be different too. I had planned on making it as low as possible though.
$crillaTor
Postby $crillaTor » Mon Aug 17, 2015 9:14
I too would like to do something along these lines.
Are you using existing LIM bolt-holes to attach that?
It looks like it bolts up where the EGR valve or whatever used to be. I'm gonna have to modify mine a bit lol. I forgot about that, I don't have those bolt holes.
