Being heavily obsessed with my rx7's I want to add a full standalone before moving in any other direction with my build in regards to additional engine modifications.
For a while now, Adaptronic has had my attention with the plug&play ecu they have available for the FC s4 or s5.
Megasquirt is an all time favorite, low cost but must be built from scratch.
Rtek is low cost, plug&play, mildly capable but limited to the AFM and other parameters.
What do you have?
What engine management does your Wankel use?
Its not really accurate to claim megasquirt must be built from scratch these days. Many places like https://www.diyautotune.com/ will sell you a fully assembled kit. The only complicated part tends to be converting the MS wiring connections to the harness you are using, if a patch kit isn't available.
I've used AEM, Haltech, and MS on various non-rotary projects.
In my experience, MS is finicky. It'll work at a basic level, but its difficult to fine tune that last 5% of polish.
AEM is nice, but I'm not a fan of how their software is setup, it expects a certain mental model that doesn't quite make sense to me. AEM also seems to be slow to evolve, which means you may be figuring out some way around a limitation because what you want to do isn't directly supported.
Haltech is pretty nice now, but their older products had some issues which seems to have sullied Haltech's reputation with some folks.
For the most part, the basics of an EMS are the same. The differentiating factor between various solutions tends to be the support, software, and advances feature list.
Brigdh wrote:Its not really accurate to claim megasquirt must be built from scratch these days. Many places like https://www.diyautotune.com/ will sell you a fully assembled kit. The only complicated part tends to be converting the MS wiring connections to the harness you are using, if a patch kit isn't available.
Now that I sold my bike and have worked over 140 hours the last two weeks I should be able to afford a standalone unit. I somewhat like the MS-3 specially after seeing Aaron Cake's cosmo build it seems capable enough.
Now I think Adaptronic has tremendous support, specially on the RX7club forum but I have read it comes with it's limits. I want something that will last a while before having to upgrade. My test bench will be the GTU after I find a healthy swap for it.
Not a fan of MS-anything
Really like AEM, done a lot of work with them over the years and believe they have the best customer support and the most user friendly product.
Motec is awesome but expensive
Haltec is not awesome
- millertime
