E-brake
Postby RX-7 Chris » Wed Jan 09, 2008 9:14
Back to the lever that is so much fun to pull while your driving.
Maybe we should call it the ET-Brake, because you may need an ET if you pull it while driving and hit a pole.
Postby tsx_guy » Wed Jan 09, 2008 9:14
<div class='quotetop'>QUOTE (RX-7 Chris @ Jan 9 2008, 04:16 PM) [url=index.php?act=findpost&pid=17215]<{POST_SNAPBACK}>[/url]</div>
"Back to the lever that is so much fun to pull"[/b]
dude....do you realize what you just said? ROFL!
Postby GR-8 » Wed Jan 09, 2008 9:14
Only you would notice that.
goldrocket
Postby goldrocket » Thu Jan 10, 2008 9:14
<div class='quotetop'>QUOTE (MazdaTom @ Jan 9 2008, 07:58 AM) [url=index.php?act=findpost&pid=17084]<{POST_SNAPBACK}>[/url]</div>
STOP CALLING IT AN EMERGENCY BRAKE! It's a PARKING brake. You never want to apply difficult to modulate braking force to the rear tires in an emergency unless it's a last resort- as in total hydrualic failure to all other brakes. If it was truely an emergency brake, it would probably act on the front brakes. Have you ever tried to bring your car to a stop using only the parking brake? It doesn't work very well. Front brakes do something like 70-80% of the total braking on most cars. That's why "typically" rear brakes are smaller than the front (although my Protege is an exception to this rule) and almost always the front discs are vented while the rears are solid.
But if your parking brake can't hold your car on slight inclines, it's in desperate need of adjustment. After I swapped my rear pads, my parking brake got all jacked up until I tightened it.[/b]
I always thought that was a steering brake!
Al says
Postby MazdaTom » Thu Jan 10, 2008 9:14
<div class='quotetop'>QUOTE (goldrocket @ Jan 10 2008, 06:23 AM) [url=index.php?act=findpost&pid=17289]<{POST_SNAPBACK}>[/url]</div>
I always thought that was a steering brake![/b]
This coming from a guy with RWD. You shouldn't need to resort to this handle with RWD- you've got a steering pedal!
Postby RX-7 Chris » Thu Jan 10, 2008 9:14
<div class='quotetop'>QUOTE (6i_guy @ Jan 9 2008, 08:40 PM) [url=index.php?act=findpost&pid=17241]<{POST_SNAPBACK}>[/url]</div>
dude....do you realize what you just said? ROFL![/b]
I figured you would find something like that.
Postby Colombia28 » Thu Jan 10, 2008 9:14
LOL at this thread! :lol:
Postby tsx_guy » Thu Jan 10, 2008 9:14
<div class='quotetop'>QUOTE (Colombia28 @ Jan 10 2008, 05:25 PM) [url=index.php?act=findpost&pid=17440]<{POST_SNAPBACK}>[/url]</div>
LOL at this thread! :lol:[/b]
thanks for adding value here Andrew...I was just talking to Josh and Lee about how you are one of the most productive mods in the forum..... :huh:
<div class='quotetop'>QUOTE (6i_guy @ Jan 10 2008, 07:17 PM) [url=index.php?act=findpost&pid=17500]<{POST_SNAPBACK}>[/url]</div>
thanks for adding value here Andrew...I was just talking to Josh and Lee about how you are one of the most productive mods in the forum..... :huh:[/b]
:lol: I do what i can.
