Reputable rotary mechanics in the Denver/Boulder area?
RXMiles
Postby RXMiles » Sat Dec 29, 2012 9:14
So far I have not come across any shops that work with our engines. There is a shop in North Boulder called Coyote Motors, I believe. The owner of the shop has a good rep for working on Mazda's but said he'd no longer work on rotaries. :(
Any good shops?
yoojeankim
Postby yoojeankim » Thu Jan 03, 2013 9:14
Mofab LLC.
1995 Chaste White RX7 "The White Mamba" :cool:
Brigdh
Postby Brigdh » Thu Jan 03, 2013 9:14
I don't have the info in front of me right now, but there is supposedly a place in Denver called Import Motors (I think) that started working on rotaries, and branched out to other things. I've never been there, I just found their info somewhere in regards to having worked on rotaries, and wrote it down.
Postby Learjet45 » Thu Jan 03, 2013 9:14
You'll find all the best rotary mechanics here on this forum! Almost anything you might need to do can be accomplished with the help of the rotary owners on here.
Postby RX-7 Chris » Thu Jan 03, 2013 9:14
What are you having trouble with? I see you have an FB, what year and model is it?
G-Man
Postby G-Man » Thu Jan 03, 2013 9:14
Coyote Motors is top-notch. I've been a client for 18 years. But if Wolfgang's no longer working on rotaries...
I'm in Boulder and happy to see if I can help - though I will try to sell you my race car.
And there is a lot of expertise on this forum.
What do you need done?
Brigdh
Brigdh wrote:I don't have the info in front of me right now, but there is supposedly a place in Denver called Import Motors (I think) that started working on rotaries, and branched out to other things. I've never been there, I just found their info somewhere in regards to having worked on rotaries, and wrote it down.
Found my notes, its Precision Import Repair at
3030 West Hampden Ave
Sheridan, co 80110
303-797-6510
confusionisbad
Junior Member
Postby confusionisbad » Thu Jan 03, 2013 9:14
I'm almost positive Mofab sent out the engine they had to Goopy to get built.
yoojeankim wrote:Mofab LLC.
boosted12a
Postby boosted12a » Fri Jan 04, 2013 9:14
FB are easy to work on, im taking mine to get tuned at this shop :http://www.grid1motorsport.com/
D Walker
Postby D Walker » Fri Jan 04, 2013 9:14
I know a guy :)
Lots of experience with all of the rotaries of all generations, currently racing rx8's inn Pro racing. Feel free to give me a call at 7202125838. The address on my grid-1 site is wrong but all the rest of the info should be correct.
Cheers! Don
tony
Junior Member
Postby tony » Fri Jan 04, 2013 9:14
Along those lines. Are there any shops in the Denver Metro area that rebuilds rotaries? I have a FD that needs its 3rd motor. I was googling for shops and came across this thread.
confusionisbad
Junior Member
Postby confusionisbad » Fri Jan 04, 2013 9:14
How many shops have you opened and closed Don?
D Walker
Opened and closed? Just one, and I closed it only to open GRID-1 when I decided to go PRO Racing and limit the amount of work I do on street cars. Most of what I do now is roll cages, tuning on the dyno, chassis and suspension setup, etc. and of course, racing.
EDIT- Occurred to me you might have been asking how many locations I have been in-
The first was in Aurora and I ended up moving because we had a couple of customer cars broken into and the other tenant was a PITA.
The second was in Commerce City and I would have stayed there or bought the building but the owners wanted too much for the rent compared to other properties that were available and we moved to the Englewood location as a temporary location with the intent to build or buy if something came available. Unfortunately I have been too busy racing etc. and back-burnered the hunt for a property.
I just moved from the Englewood building because they were threatening to raise the rent, and I was paying too much per sqft as it was, and had a 1000sqft of showroom and office space I never used, a complete waste of space.
The "new" location is OK, but I am looking for a building to buy, tired of paying rent and need a facility more tailored to what I do.
D Walker
tony wrote:Along those lines. Are there any shops in the Denver Metro area that rebuilds rotaries? I have a FD that needs its 3rd motor. I was googling for shops and came across this thread.
I rebuild rotaries. I tend to have most parts to rebuild rotary engines- 13B and Renesis- on hand and in stock, mostly because we race them.
