Fd wheels on FC?
2slw4u
Fd wheels on FC?
Postby 2slw4u » Wed Oct 03, 2012 9:14
Will the fd wheels bolt right up to the fc? or do i need a spacer to fit them? If i do need a spacer what kind of spacer will I need to fit these wheels onto my fc?
Thanks guys!
Postby chickenwafer » Wed Oct 03, 2012 9:14
I know the bolt pattern is the same but I also know you need a spacer. I want to say between 5-10mm but don't hold me to it. If you check out rx7club in the 2nd gen FAQs it has the spacer info in there.
Postby iani1.1 » Wed Oct 03, 2012 9:14
8mm and above at the least and depending on what size tires you planning to put on
2slw4u
ok, so if i plan to run the factory 2055516s will i just need the 8mm?
atleast 10mm. sorry about that.
but here's an explanation since ive had a few to drink LOL. http://fc3spro.com/TECH/FAQ/fdfit.html
Users browsing this forum: No registered users and 83 guests
