My New Toy
Postby iani1.1 » Sun Oct 03, 2010 9:14
grats, sorry i didnt get to call you back on saturday. i stayed up late working on my car and woke up like around 11 lol.
how hard was it to put that clutch rod back in? lol
323Bf
Postby 323Bf » Sun Oct 03, 2010 9:14
i like it... the rx-7 sa is a very cool model :)
http://www.mazdascene.at
http://www.pernull-racing.at
Postby RX-7 Chris » Mon Oct 04, 2010 9:14
iani1.1 wrote:grats, sorry i didnt get to call you back on saturday. i stayed up late working on my car and woke up like around 11 lol.
Getting the rod back in was easy, I'm having trouble getting the clutch to bleed out. I get no pedal pressure. Do you think you might be able to help me with that? I'm going to work on the car for a bit after work today.
323Bf wrote:i like it... the rx-7 sa is a very cool model :)
Thanks.
Postby iani1.1 » Mon Oct 04, 2010 9:14
Ill be a quite busy today but how does tomorrow sound?
Edit: actually I can free up sometime today. Just give me a call.
iani1.1 wrote:Ill be a quite busy today but how does tomorrow sound?
works for me. I will only have an hour but that should be plenty. I can be there at 6pm.
Postby tsx_guy » Mon Oct 04, 2010 9:14
sweet dude...i expect to see you at the BWW meet on thurs now. ;)
Messed with it again on Sunday.
I cleaned the air flow meter, replaced cap and rotor, ran seafoam through the car, tested the TPS (found it was sticking). I also adjusted the leading timing.
What still needs to be done:
-finish checking timing
-install replacement TPS
-check 6 port actuators
-check fuel pressure
-test temp sensor
-test air flow meter
-test ecu
-run codes
-replace air filter (very hard to find)
-change all fluids including tranny and rear
-grease everything
-clean interior
Postby speedjunkie » Mon Oct 04, 2010 9:14
RX-7 Chris wrote:It Runs!!!!
Thanks to Ian, Zico, Simon, and Eric
I didn't really help but thanks for the props anyway HAHA.
Stealth01 wrote:What are we going to do when Chris rolls to a meet in a car that isn't primer-black?
YOU probably won't do anything because YOU are never there. LOL
And guys, I haven't left for home yet, probably tomorrow morning, so I'll be here tonight if you want to stop by.
cool. I will be there around 5pm tonight.
Ill stop by too. To help chris
cool thanks, I thought you couldn't show tonight?
finished my errands early.
Postby RX-7 Chris » Tue Oct 05, 2010 9:14
it was driving Ian and I nuts last night. We can't get it to idle nice.
Postby tsx_guy » Tue Oct 05, 2010 9:14
you have to whisper it sweet nothings chris, (refrains from comment about his wife)
