OK, I posted something about going to SevenStock back when I first joined this forum in 08, but I'm serious about going this time. I made sure today at work that I can get the time off for it, and the car is running really well, and there are friends I'd like to see out in Vegas on the way there and back, so it's a go. Dave (chickenwafer) is probably going, and I'm the only other one right now. Who else is in?
I think it's changed a bit this year, because I heard it was at a race track this year instead of the Mazda HQ in Irvine. We'll see.
And I believe it's Sept 29th if I remember right. It's 109am, gimme a break lol.
SevenStock 15
- Saul_Good
I've been to two Sevenstocks. The one at Mazda HQ was so-so. The magazines made it look more extravagant than it actually was. The plus though is that you'll be in Socal and there's lots to eat and see. The one at the track was better because you get to see and run against them (each other).
Edit: The second one I went to wasn't Sevenstock it was Mazfest which was at the track. I just checked and this time Mazfest and Sevenstock have partnered up to have it at Willow Springs. A plus for you SpeedJunkie is that it's right around the corner from Edwards AFB which you could make use of your military status and use the Billeting there.
eliminster
- Saul_Good
Found out the organization I frequented will be running the track portion of this event. These are good guys. Whoever is going should definitely consider this opportunity to run on this track.
https://www.extremespeedtrackevents.com/event-registration?eventId=63&task=event_register&type=reg_individual
Users browsing this forum: Bing [Bot] and 61 guests
