Some Pictures from the 2008 24 hour Daytona
And see those Rock Blocker headlight overlays? Those are to help prevent broken headlights. Also, the color (yellow in this case) helps to identify which class they are in so at night drivers know who to let by and who they are racing for position.
- Colombia28
Engine 20B Three rotor rotary engine (1,950cc)
Max Power 425HP @ 8500RPM
Max Torque 285 ft-lbs. @ 7600
Max RPM 8800
Dry Sump Lubrication
Bosch 4.3 ECU
Gearbox Emco Daytona Prototype
Six forward gears and one reverse
Ring and Pinion 10/35
Bodywork All carbon fiber
73.5 inch width
174 inch length
Suspension Dymanic Suspension DSSV shocks
Front and Rear adjustable anti-roll bars
18x11 Racing Hart wheel front with 285/645-18 Pirelli Racing tire
18x11.5 Racing Hart wheel rear with 305/660-18 Pirelli Racing tire
Brakes Dual master cylinders with balance bar
Four piston Alcon front and rear calipers
Cast iron vented Alcon rotors front and rear
Pagid racing brake pads
http://video.google.com/videoplay?docid=-3...h&plindex=3
Max RPM 8800
Bosch 4.3 ECU
73.5 inch width
174 inch length
Users browsing this forum: Baidu [Spider], Bing [Bot] and 199 guests
