Today I realized I had a low beam bulb out. It was on the driver's side. These bulbs are not like anything I have dealt with in the past, so I figured I would do a quick write up for others that may find benefit.
Items needed:
H7 bulb for halogen applications
Dielectric grease
Wide blade flat head screwdriver or plastic pry bar
Rubber gloves if you want to be very careful with the bulb.
To gain access to the bulb remove the battery air intake and additional plastic shield over the headlight assembly. In my case I had to remove my sri.
You will see a connector on the back of the bulb socket. Depress the two tabs on either side and pull straight out. You will now have two exposed connector tabs.
There is a rubber shield around the bulb. I started at the bottom and using my fingers pried the lower part off and worked my way around to the top.
With the rubber removed there is a retaining wire holding the bulb and receptacle in place. Push in on the left side of the wire and lift up to slide it off the small metal tab holding it in place. Pull the bulb out. It is actually retained in a black adapter receptacle. Use a screw driver or plastic pry bar and pry them apart. Apply dielectric grease to all tabs and reassemble in reverse.
The passenger side is the same except there is nothing to remove to get to the bulb.
Low beam bulb replacement how-to
- AuroraAxela
Moving our power steering reservoir helps a bit with passenger side
42boxer wrote:should have put some hids in while you where at it
I have a cracked passenger side fog light, so that will be the next replacement. I was looking around on ebay last night and found these, which may work.
AuroraAxela wrote:Moving our power steering reservoir helps a bit with passenger side
I think it is mandatory to get to the high beam bulb in fact.
Users browsing this forum: No registered users and 165 guests
