miata wont start
borisovich
miata wont start
Postby borisovich » Sat Jul 23, 2011 9:14
so i was about to leave work and my car doesn't start. so i jumped it and it started but once i turned on my lights car shut off, i jumped it again it did same thing, so than i jumped it with lights on and it was fine (i didn't even try to turn it off) so i turned on my emergency lights for no reason and i almost died..... so i drove home 12 miles drive and when i got home i turned off the car and it wont start back on again...... what could be wrong?
Postby erod550 » Sat Jul 23, 2011 9:14
Sounds like a dead battery to me. And it could be caused by a bad alternator that let the battery drain in the first place. This would explain why it died when you turned the lights on if the alternator is not generating enough current while the car is running. I'd take it to Autozone or another parts store and have the battery tested, and while they are doing it they can usually tell you if the alternator is charging or not by how much current is going through the electrical system while it is running.
borisovich
thank you for the info, and if it is alternator, is it a pain to change it on miata?
Outlaw
Postby Outlaw » Sun Jul 24, 2011 9:14
Ditto on what erod said. been there, done that with same results. My alt was putting out zilch and it sucked the batt dry. Wound up having to buy now alt and batt. Bummer:mad:
94mx5
Postby 94mx5 » Sun Jul 24, 2011 9:14
Alternator isn't a big deal to change. If you have AC/PS then you have to remove that belt first, then the alt/wp belt. 1 plug and 1 bolt on wire to remove (disconnect battery first). Also 2 bolts to pull the alternator out. This also requires the air intake tube coming out first, which often requires the top radiator hose to come off at one end. Might plan on changing the belts while you are in there as well if needed.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 199 guests
