Its a little early, but why not
Postby tbot » Mon Dec 06, 2010 9:14
For those of you that don't know, my motor seized about 2 months ago and Mazda NA denied warranty coverage. SO, I'm going to be doing a built bottom end w/ forged internals. So far here's my parts list:
Part Description Item Number Price
ARP Headstud 218-4702 $161.00
ARP Mainstud 218-5402 $128.14
Complete Gasket Kit SU310270 $299.00
Carillo Rods MA-23DISIT-65927H $935.00
Wiseco Pistons K640M875 $499.00
Clevite Main Bearing Set MS-2245AL $85.00
Rod Bearings OEM SU211SE0 $88.00
All for a grand total just in parts of: $2195.14
Yeah that hurts...anyways...pics of the important parts.
Pistons
Rods
Studs
I've already found places to do the head work and machine work thanks to my cousin who professionally builds drag motors (he has a 10 second small block camaro). So now its just a matter of money to make it all happen.
I'll try and get pictures of updates, but its going to be hard not having any transportation to get anywhere, but I'll do my best.
There's a few other things too that i'm going to be looking into getting, such as:
Upgraded Injector seals
Upgraded High pressure relief valve for fuel rail
Exhaust mani (not sure which one yet, but have it limited down to a couple)
Then we'll see about turbo, in top mount form, and a fmic.
Post up any questions, concerns, ideas that you have. I'm open to hear them.
Postby RX-7 Chris » Mon Dec 06, 2010 9:14
can't wait to see this build progress.
Thought I'd share some of the ideas I have...
No its not my car...but thats a GT3076, so as the owner of the car said...plenty of room for a GT35r. I'm not sure what turbo I go with, but in all honesty thats later down the road.
Will you have the motor blueprinted and balanced?
Postby Huzer » Mon Dec 06, 2010 9:14
Is there even an engine in those second set of pictures?!
Good luck with the build.
RX-7 Chris wrote:Will you have the motor blueprinted and balanced?
Yeah i will. I'm taking no chances w/ this haha. Plus its really not that much to have it done.
Huzer wrote:Is there even an engine in those second set of pictures?!
Thanks Tim! And yes its in there somewhere haha. That guy is gunna end up using a Borgwarner thats basically a GT4088...so WAY bigger than anything I'll be doing.
Postby Stealth01 » Mon Dec 06, 2010 9:14
See, and there's a silver lining to this dark cloud of zoom-zoom boom. :) Good luck!
Postby chickenwafer » Mon Dec 06, 2010 9:14
Good luck man, can't wait to see the results!
As far as turbo sizing, what kind of power are you looking for?
450 awhp. Been done on a GT3076 on our platform. Might be safe and look at a GT35. Dunno yet tho, too far off.
Postby ~Barn~ » Mon Dec 06, 2010 9:14
I'm both not envious and envious at the same time. That being said, I sure hope my car comes back with clean bill of health!
Image 720.935.6438
tbot wrote:450 awhp. Been done on a GT3076 on our platform. Might be safe and look at a GT35. Dunno yet tho, too far off.
Get the turbo that gives you the best response but still makes the power you want.
I would look at the new line of billet turbos, for the power you're after you can run a Garrett GTX3076R billet or a Presicion 5557 billet with dual ball bearing CHRA's and get excellent spool but even more top end because of the efficiency of the billet wheel.
The GTX3076R compressor map:
Compared to the non billet GT3076R:
As you can see, it flows much, much more. And, also pretty obviously pointed out in the map is the higher the boost, the better the efficiency. I mean you can flow 65lbs/min of air at a PR of 3.25! Win/win
yeah imm fully aware of the new ones hehe. i'm just not there yet to be deffiniative of a turbo.
rmeeker13
Postby rmeeker13 » Tue Dec 07, 2010 9:14
What are u doin? Get a real car and build it! :)
Thats alot of money to spend for only 450awhp!
Good luck homie, hit me up if u need any assistance with the build.
Postby tbot » Tue Dec 07, 2010 9:14
I would get another car, but can't afford to. And since I have to rebuild the motor anyways, its kinda to the point of no return. And yes its a lot of money, but I appreciate the fact that no one on the roads really knows what this car is, let alone one with that much power. It'll be quick enough to put to shame the majority of people on the roads, plus has the amenities that make it a nice car.
With boost coming on much later than the stock snail, it should make for a fairly decent daily driver as well. After I'm done, all the fail with this car will be fixed/replaced with appropriate parts. Plus I actually do really like the car.
Besides...I HATE quiting. Looks like I will be the only one in Colorado that won't give up on this platform haha.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 59 guests
