Need help diagnosing something not working.
Postby ~Barn~ » Thu Dec 02, 2010 9:14
So I'm having a problem.... I've had my car in storage for about 2 weeks. It was essentially open-air but underground. Definitely very low temperatures, but no element exposure. Prior to leaving it, the car was running great. Super fast, smooth everything.
The other day however, I get it out and drive it. After about 10 minutes or so, it starts to dawn on me that I'm having this strange symptom, where the car's not accelerating like it's supposed to. I would accelerate briskly or flat-out floor it, and no zoom. Felt like no boost, even the sucking sound of the intake was limp. Sometimes when I'd gas it, it would putt along, gaining speed lazily until maybe 3/4 redline, and then have a real sudden hit of boost and acceleration.
I decided to undo my tune and see how things are, but really it's not any different. Long-story-short, my car is no longer making boost like it's supposed to. I floor it, and although I accelerate (slowly), something is majorly malfunctioning. And like I said, I've gone back and forth between "tuned" and "stock" ECU maps, but the symptoms are the same.
At times, the car does make boost from mid to full throttle, and seems like it's driving okay. Almost like it's back to normal. Then out of nowhere I get the symptoms again of absolutely no zip all the way to read line, or *maybe* a late hit of near red-line boost.
So I've decided to do some logging with my AP, to see what's going on. A recent 4th gear WOT pull from about 1/2 redline shows negligible value differences for:
Accelerator positioning
Throttle positioning
Short and Long FT's look similar enough.
Fuel pressures are on par.
Wastegate Duty's are close.
AFR's look good, and a variety of other values seem okay, or "close", if not mildly different. And this is all in comparison to a log from a few months ago, when the car was running fine (and in the same state of tune).
However!... The glaring differences are things like:
Working vs. Not Working
Mass Airflow (g/s) - Low 200's vs. Low 100's
Inj. Pulse Width (ms) - High 6's vs. Low 4's
Injector Duty Cycle (%) - Low 60's vs. Low 30's
Calculated Load (%) - 130~160 vs. Low to High 90s
MAF Voltage - 4's vs. 3's
Fuel Injection (mg/cly) - Mid to Hi 9's vs. Mid 5's to Mid 6's
Spark Advance - 9~12 vs. 15~17
And of course Boost (psi) - 16~18 vs. 4~5
Anybody have any thoughts on what might be out of whack here? I've talked with 'Bot a bit about this, and I've done some cursory checking of various hoses and vac-lines connecting to and about the turbo, inlet, and BPV... Granted... I don't know what the hoses do, but everything at least looks hooked up and not damaged in any way. (?)
Thanks in advance if anybody has any further troubleshooting ideas or anything really.... This is kinda bumming me out...
Image 720.935.6438
Some data logs to download if interested...
Image 720.935.6438
Postby tbot » Fri Dec 03, 2010 9:14
I also noticed when ur not getting any boost your AFR's are SUPER rich for a long time. Its like the exact same symptoms as if you were getting knock and the ECU is trying to correct it.
I think its time to take your intake and TIP off and take a look at the turbo. See if there's any shaft play (which would be parallel movement of the shaft) or if the wheel's are spinning freely.
Postby ~Barn~ » Fri Dec 03, 2010 9:14
Are you talking about when I'm WOT and not getting any boost? I thought it looked like my AFRs are about what they were, when things were working well - (11's decreasing into 10's).
Image 720.935.6438
On the logs you sent me, going WOT, with no boost your AFR's were in the 9's. Like I said, its almost identical to what happens when the ECU see's KR, save for pulling timing cause yours is WAY advanced lol. I really think there's something else going on here besides the turbo, especially since the throttle plate is closing even tho the accl. pedal is at 99%.
Postby erod550 » Fri Dec 03, 2010 9:14
Were the logs taken on the stock tune? That could explain the rich AFRs and throttle closing even though the pedal is still to the floor. One of the biggest reasons for getting an AP/Standback is to keep the throttle plate open longer since the stock tune likes to close it as you get closer to redline.
The logs that I sent to 'Bot were under stock conditions, the logs that I have posted up to this thread are under tuned condition.
Image 720.935.6438
Erod I realize that, but in comparing the logs, boost vs no boost, there's a huge difference. We aren't talking about 10% ish, its more or less a 40% difference and its no where near redline where this is happening either. The stock tune will NOT keep it closed that much. As for the AFR's, they are richer longer than what they should be. Its not just "dipping" into the 9's like a stock tune should be, its deep into the 9's.
I appreciate the input, but its really just a redundant statement of the obvious. I wouldn't be posting up what I said if it weren't for a noticeable reason beyond what is considered "normal" even for a stock tune.
Barn after looking at the tuned logs I really think your turbo is done. Your WGDC is maxed out. In comparison, when I was running 21ish psi on my tune my WGDC was only about 64% max, yours is 93% (which iirc it doesn't max out at 100% for some reason, it only goes as far as 95%).
Even when you're not getting boost the WGDC is 86%. Looks like its time to go BT on your car :D
One other thing to back this up, the boost air temps when you get boost are 150ish. With ambient temps I'm going to assume in the 50's, even with a stock TMIC those are WAY too high. Basically your turbo is just pushing hot air. Look at the non-boost log boost temps...they're in the 80's, that should be about what temps are when you have boost, even with stock TMIC.
Egh... no worries. I'll have the professionals at Groove fix it.
Eric, thanks for the input.
Image 720.935.6438
its gunna be spensive! just saying
Well.... probably.... I just don't have the knowledge, tools, or even really the space to start repairing something this intense.
Checking for disconnected or chewed hoses is one thing. Disassembling major engine components and actually putting them back together again (correctly), is another!
tbot wrote:One other thing to back this up, the boost air temps when you get boost are 150ish. With ambient temps I'm going to assume in the 50's <Snip...>
Actually, the "good" log was back from over the Summer. Ambient temps were a lot hotter than the "bad" log I pulled the other day.
Image 720.935.6438
Postby kingtut » Fri Dec 03, 2010 9:14
~Barn~ wrote: a lot hotter than the "bad" log I pulled the other day.
Sorry, I couldn't help myself.
....back on topic:)
So I decided to Cobb my car back to a "stock" state of tuning during my lunch, and give it a bunch of WOT passes to see how things are today.
Surprisingly, the symptoms (while not 100% gone), have reduced pretty drastically. I don't know if I'm finally getting deeper into my new tank of gas, and the car is just adjusting, but it's better.
More to come....
Image 720.935.6438
Users browsing this forum: No registered users and 169 guests
