front fog light replacement!
wyosaint
Postby wyosaint » Fri Jan 02, 2009 9:14
These suckers run 147 from the stealership!!!
Postby Colombia28 » Fri Jan 02, 2009 9:14
Do you need to replace the assembly or the bulb? Whats wrong with it?
wyosaint
Colombia28 wrote:Do you need to replace the assembly or the bulb? Whats wrong with it?
The bulb works fine, a rock must have hit it, its got a gaping hole and the entirething can fall apart if I just took out one sliver, so to prolong the bulb I just need the cover. Called up denver and that's the price they gave me.
wyosaint wrote:The bulb works fine, a rock must have hit it, its got a gaping hole and the entirething can fall apart if I just took out one sliver, so to prolong the bulb I just need the cover. Called up denver and that's the price they gave me.
Ah shity. Call up Burt, CMZC members get 10% off parts, so that may help a bit.
If you get it replaced, you should look into getting some Lamin-X for the fogs, i had Eric at Eclipse Tinting clear Lamin-X my fogs and headlamps in the hopes it will prevent this sort of thing.
Postby SpeedRacer » Fri Jan 02, 2009 9:14
yep happened to both of mine with less than 100 miles on my car :(
Rich
Postby Rich » Fri Jan 02, 2009 9:14
wyosaint
I'm at burt mazda, I had to come here for some other problems, like a possible steereing wheel prob from the noise its making and a possible leak from some pump. Go mazda...
SpeedDemon
Postby SpeedDemon » Mon Feb 23, 2009 9:14
I have allways wondered since most sites niglect to put the speed 6 seperate from the 6 is that because a majoirty of the parts are similar or just because the speed 6 was kinda a limited edition kinda thing so they dont bother with it?
Btw I love your car wyosaint. But my oppinion may be a bit bias haha. Hope you get ur Speed fixed up soon.
Users browsing this forum: Bing [Bot] and 96 guests
