I made a post over on 6Club with some DashHawk logs. If you guys can, check it out and give me some insight. My car is insane....
http://forum.mazda6club.com/index.php?showtopic=106714&hl=
Need help!
firestoned
i see a bunch of pretty colors...lol
Rich, I honestly dont see anything MAJOR with those logs. Fuel pressure bounces around a bit, but no obvious fuel cut, afr seems really good..
I think you need to log with the standback so you can see what your boost looks like. Its difficult to determine if you are getting fuel cut or boost cut. Those logs dont show any fuel cut, and you cant log boost cut with the Dashhawk, because as you mentioned, the numbers are skewed...
firestoned
firestoned
the Absolute TPS is kinda funky on the last log...i wonder why it dips in the middle like that...is that your cut? the load spikes are the obvious cut spots, but the fuel press doesnt even match the cut spots, so I would possibly rule out fuel cut. If the damn dashhawk would read accurate boost, we could have more of an answer....but it sucks, so it doesnt
