In trying to diagnose the same issue on my van, I threw a spare battery and some jumper cables in back. Turns out there was a small light that would never go off that would drain the battery enough over a couple days. Same symptoms as the starter would click but no turn over due to low power, but different problem.
In the meantime, as mentioned, I would park on a slight downhill. Wouldn't be the first time that saved my butt.
Starting issue
Yea at home I live on a hill and at work I'm in a parking garage so worst case I can just push it to the ramp going down to the next level and easily jumpstart it. It's been doing this since I bought the thing a year and a half ago though so I'm not too worried about it dying really soon lol.
Yea now that I think about it, it started after the swap. We didn't take the starter off so it has the starter from Ron's engine. We did the swap like 2 weeks after I got the car so I guess it just ran together, heh.
It is exactly what my car was doing since I got it and about 2 weeks ago the starter completely died.
Well, replaced the starter and it did the exact same thing on first startup so it obviously wasn't the starter. Oh well, at least now I have a new one and it should last me the rest of the time I have the car. Guy at Autozone said it could be the push button switch, might not be a high enough amperage. I dunno if I care enough to dig it out and try to replace it. Like I said, it's been doing it for a year now and if I'm not worried about the starter crapping out, I will just deal with it. Even though it's a pain, it still does start every time, just sometimes takes more button presses than others.
I have an S2000 button installed by a previous owner. This pic is not my car but shows the location and the button is the same.
I would also look at replacing the battery cables. I had a problem with my other car years ago that I thought was the starter and it turned out to be a bad cable.
Yea that was my next thought. But with the battery being in the trunk it would be a much bigger pain that replacing it all underhood, heh. Have to weigh which is worse, the pain in the ### replacing the cable or the pain in the ### of pushing the button several times to start the car.
in the end replacing the cables will be the best choice.
Users browsing this forum: No registered users and 144 guests
