Miata Turbo For Next Year
arctic_blue83
Postby arctic_blue83 » Mon Nov 19, 2007 9:14
<div class='quotetop'>QUOTE (Greek8 @ Nov 19 2007, 11:53 AM) [url=index.php?act=findpost&pid=11416]<{POST_SNAPBACK}>[/url]</div>
Really. That sucks. To many problems or no intrest.[/b]
Actually, I believe they made a Mazdaspeed Miata for both 2004 & 2005, it was canceled with the addition of the new chassis Miata in 2006. I think it sold alright, but it wasn't really that powerful, they basically did the same thing as they did with the Mazdaspeed Protege, they just turbo'd the factory engine without swapping internals or anything. It came with a 178hp 1.8L turbo motor, so not exactly a ton of power.
Buffalo
Postby Buffalo » Mon Nov 19, 2007 9:14
With the plans for another Mazdaspeed Miata, that means its another year before we see a ms rx8 or a new rx7.
Up Next: Project RX-8!
turbo99jetta
Postby turbo99jetta » Mon Nov 19, 2007 9:14
<div class='quotetop'>QUOTE (arctic_blue83 @ Nov 19 2007, 12:21 PM) [url=index.php?act=findpost&pid=11432]<{POST_SNAPBACK}>[/url]</div>
Actually, I believe they made a Mazdaspeed Miata for both 2004 & 2005, it was canceled with the addition of the new chassis Miata in 2006. I think it sold alright, but it wasn't really that powerful, they basically did the same thing as they did with the Mazdaspeed Protege, they just turbo'd the factory engine without swapping internals or anything. It came with a 178hp 1.8L turbo motor, so not exactly a ton of power.[/b]
Brandon you would be correct, the mazdaspeed miata was for both 04 and 05. It was canceled with the new miata in 06, but also look at the history of mazdaspeed... 2 year production runs for the most part.
<div class='quotetop'>QUOTE (Huzer21 @ Nov 19 2007, 11:57 AM) [url=index.php?act=findpost&pid=11419]<{POST_SNAPBACK}>[/url]</div>
I kinda agree there. I don't like the extremely generic nose on the new model. They all look like they sit rather high, too. Lowered with a tastefully aggressive front clip, and I think it would do quite a bit for the looks. From the A pillar back, it's fine.[/b]
with all the new saftey requirements with hitting people all the new front noses of cars are going to be somewhat like this..
<div class='quotetop'>QUOTE (Sleepy Buffalo @ Nov 19 2007, 12:32 PM) [url=index.php?act=findpost&pid=11436]<{POST_SNAPBACK}>[/url]</div>
With the plans for another Mazdaspeed Miata, that means its another year before we see a ms rx8 or a new rx7.[/b]
with this you will almost garenteed not see a RX8 Mazdaspeed Version. late 2009 or 2010 expect a change on the 3 and the rx-8.
Buffalo
I guess i will be forced to create my own mazdaspeed version stateside.
Postby Huzer21 » Mon Nov 19, 2007 9:14
<div class='quotetop'>QUOTE (Sleepy Buffalo @ Nov 19 2007, 01:02 PM) [url=index.php?act=findpost&pid=11446]<{POST_SNAPBACK}>[/url]</div>
I guess i will be forced to create my own mazdaspeed version stateside.[/b]
Ditto.
Rich
Postby Rich » Mon Nov 19, 2007 9:14
Did anyone else read this????
From the first paragraph...
"...it is known that a 300 HP version has been built for the future MazdaSpeed6 featuring a slightly larger turbo."
Can anyone confirm or give us a date? I'm wondering if they'll offer a stage kit for old Speed6's...
RedRoadster
Postby RedRoadster » Mon Nov 19, 2007 9:14
I did think it was interesting that the '06s were at about the same power levels as the MSMs, so if there isn't a bunch of weight gain for the MSMNC (NA, NB and NC denoting the body styles through the generations), so let's guesstimate at 260 hp with 100 additional lbs, and the power to weight drops to 10.0. That should be easy enough, no?
95 Classic Red Miata - 'Kona'
Flyin' Miata stuff:
arctic_blue83
<div class='quotetop'>QUOTE (Red95FMII @ Nov 19 2007, 04:00 PM) [url=index.php?act=findpost&pid=11473]<{POST_SNAPBACK}>[/url]</div>
I did think it was interesting that the '06s were at about the same power levels as the MSMs, so if there isn't a bunch of weight gain for the MSMNC (NA, NB and NC denoting the body styles through the generations), so let's guesstimate at 260 hp with 100 additional lbs, and the power to weight drops to 10.0. That should be easy enough, no?[/b]
Oh absolutely, I'm sure if Mazda releases a MS Miata with around 260bhp and only gains around 100 lbs in weight (which sounds about right with the addition of all the excess piping, the turbo, intercooler ect) I'm sure the upcoming MS Miata will have no problem keeping up with (or smoking) the Sky Redline. I was only referring to the current naturally aspirated Miata vs Sky Redline.
Users browsing this forum: No registered users and 148 guests
