Mazda cai "NOW AVAILABLE"
bobopud
Postby bobopud » Sun Dec 28, 2008 9:14
I don't want to have to buy the airflow straightener. If Mazda found a problem with it that triggered enough problems for them to redesign the thing, then I want my money back, or a free replacement.
I spent $300+ on a part that has been found to be defective by Mazda. There should be some form of compensation.
Zwetty
Postby Zwetty » Wed Mar 11, 2009 9:14
So, is the benefit of buying the Mazda CAI that it won't void your warranty if the dealer installs? I'm wondering because I am looking at getting one, but don't want a voided warranty.
jt2589
Postby jt2589 » Wed Mar 11, 2009 9:14
Yes. That is true. If you decide to get a Mazda CAI it will not void your warranty.
GoToTheJoe
Postby GoToTheJoe » Wed Mar 11, 2009 9:14
It would be nice to know what the reason they were pulled in the first place was and if the owners of the first generation Mazdaspeed CAI's are driving around with a defective part. I haven't been able to get an answer on this yet.
--brian
2006 MazdaSpeed6 GT ** Whitewater Pearl Mica ** 5Zigen Pro Racer ZR+520 Wheels - Ceramic Bronze ** Navigation ** Integrated Sirius Radio ** Black and White Leather Interior ** 18% window tint ** Clear Bra ** Moonroof ** Wheel Locks ** MazdaSpeed CAI ** VG Sharkfin ** CF MazdaSpeed License Plate Holder ** Cargo Net ** Firestone Firehawk Wide Oval Indy 500 225/45r/18 ** Lamin-x Charcoal Headlight Protector **
bobopud
Postby bobopud » Thu Mar 12, 2009 9:14
GoToTheJoe wrote:It would be nice to know what the reason they were pulled in the first place was and if the owners of the first generation Mazdaspeed CAI's are driving around with a defective part. I haven't been able to get an answer on this yet.
I haven't gotten an answer yet either, although I have asked a few times now with no response.
GoToTheJoe
Postby GoToTheJoe » Fri Mar 27, 2009 9:14
Bump for an answer on the original Mazdaspeed CAI??
This must be one of the world's greatest mysteries...not even Mazda people know the answer!
--brian
DavidDCC
Postby DavidDCC » Sat Mar 28, 2009 9:14
I would also be interested to know what the story is here...
-David "Korben Dallas"
Base Setup: 2007 MazdaSpeed 6 GT, MazdaSpeed Cold Air Intake, Stubby antenna, 30% Tint, Synthetic oil/fluids, Aluminum Fuel Door, LTR7IX-11 Spark Plugs
Summer: RX-8 rims with Sumitomo HTR Z III (235/40/18) summer tires (unrolled wells)
Winter: Stock rims with snow tires
Mods: Forge BPV, CP-e Engine Mount, SU Silicone Boost Tubes, CP-e Nviscid™ Pipe, Rockford Fosgate 150watt Mono Amp, 8" Elemental Designs e3.8 4ohm DVC @ 2ohm
Roadrnr06
Postby Roadrnr06 » Sat Mar 28, 2009 9:14
Because the Mazda speed3 was throwing a check engine light due to an improperly sized maf sensor : ) ironically the speed6 did not have the same issue in general. My speed6 never through a code in fact. At least due to that : 0 ) as far as the warranty goes, you have to go a long way to "void" your warranty due to after market parts, so if you got an Injen intake for example the dealer wouldn't have an issue. The concept is the same, so what does a name mean? What they stand to gain is by fooling you into thinking that they have to install only factory designed parts onto your car to keep your warranty. Key here install = money. Really has nothing to do with Mazdaspeed or whatever. As a general rule of thumb, it is your service managers discretion and with a factory performance car, mods are expected. Hope that helps!
[/SIZE][/font]
Postby kingtut » Sun Mar 29, 2009 9:14
Roadrnr06 wrote:Because the Mazda speed3 was throwing a check engine light due to an improperly sized maf sensor : ) ironically the speed6 did not have the same issue in general. My speed6 never through a code in fact. At least due to that : 0 ) as far as the warranty goes, you have to go a long way to "void" your warranty due to after market parts, so if you got an Injen intake for example the dealer wouldn't have an issue. The concept is the same, so what does a name mean? What they stand to gain is by fooling you into thinking that they have to install only factory designed parts onto your car to keep your warranty. Key here install = money. Really has nothing to do with Mazdaspeed or whatever. As a general rule of thumb, it is your service managers discretion and with a factory performance car, mods are expected. Hope that helps!
That definitely helps:) After speaking to you two, I was going to go the Cobb route anyway. Just think Mazda's being a bit wishey-washey not to directly answer the question-
Users browsing this forum: No registered users and 249 guests
