front fog light replacement!
These suckers run 147 from the stealership!!!
- Colombia28
Colombia28 wrote:Do you need to replace the assembly or the bulb? Whats wrong with it?
The bulb works fine, a rock must have hit it, its got a gaping hole and the entirething can fall apart if I just took out one sliver, so to prolong the bulb I just need the cover. Called up denver and that's the price they gave me.
- Colombia28
wyosaint wrote:The bulb works fine, a rock must have hit it, its got a gaping hole and the entirething can fall apart if I just took out one sliver, so to prolong the bulb I just need the cover. Called up denver and that's the price they gave me.
Ah shity. Call up Burt, CMZC members get 10% off parts, so that may help a bit.
If you get it replaced, you should look into getting some Lamin-X for the fogs, i had Eric at Eclipse Tinting clear Lamin-X my fogs and headlamps in the hopes it will prevent this sort of thing.
2008 Cosmic Blue Speed3 - NEW
yep happened to both of mine with less than 100 miles on my car
- SpeedDemon
Rich wrote:Got a part #?
If this is what you're looking for...
http://www.trademotion.com/partlocator/index.cfm?action=getJointLocator&siteid=214264&chapter=§ionids=0,2295&groupid=2304&subgroupid=2305&make=22&model=Mazda6&year=2006&catalogid=2&displayCatalogid=0
I have allways wondered since most sites niglect to put the speed 6 seperate from the 6 is that because a majoirty of the parts are similar or just because the speed 6 was kinda a limited edition kinda thing so they dont bother with it?
Btw I love your car wyosaint. But my oppinion may be a bit bias haha. Hope you get ur Speed fixed up soon.
