JWT 700BB Twin Turbo 350Z
Postby Huzer21 » Mon Nov 03, 2008 9:14
3rd in class? Must've been a tough crowd!
Robert_K
Postby Robert_K » Mon Nov 03, 2008 9:14
Huzer21 wrote:3rd in class? Must've been a tough crowd!
A '53 MG took first and a mid 90's NSX took 2nd.
Postby Ranger » Mon Nov 03, 2008 9:14
Have you driven a car with the factory Brembos? If so, how do you like the StopTechs in comparison? I'm looking at buying this Z that doesn't have the Brembos, and would probably upgrade eventually. I loved my Brembos on my G35...but I've heard great things about StopTechs too. They're quite a bit more expensive unfortunately.
Robert_K
Ranger wrote:Have you driven a car with the factory Brembos? If so, how do you like the StopTechs in comparison? I'm looking at buying this Z that doesn't have the Brembos, and would probably upgrade eventually. I loved my Brembos on my G35...but I've heard great things about StopTechs too. They're quite a bit more expensive unfortunately.
I haven't. But during my brake research the factory Brembo's do well on the road course and the OEM non-Brembo's don't. (Trust me! ;)) Of course any upgrade to a large BBK is an improvement for heat displacement. So if you don't have any/many intentions of taking the Z to a auto-x and/or road course the OEM non-Brembo's will be fine. However I would suggest upgrading to the OEM non-Brembo StopTech Stage II kit. The kit includes; F&R Slotted or Drilled rotors, F&R Axxis Ultimate pads, F&R stailess steel lines, and 3-bottle of Motul DOT4 fluid. I had this kit before my ST BBK and its GREAT for dailt driving!!! Now if you have thoughts of becoming the next SCCA/NASA racing champ I would suggest at least the Brembo's or a BBK. Might want to also consider looking at buying a used set of G37S OEM brakes. They are silver and are at least, if not bigger, than my 4-pot/2-pot StopTechs. Also make note as you go larger on your brake set-up your wheel needs to be larger to clear the caliper. Hope this out you out some.
(Personal Opinion: Saved the money you'll be spending for the Z w/ Brembos and purchase a BBK. A front BBK is more than enough braking.)
Won't be tracking it often, if ever. I have another car for the track. :) Maybe a few open track days with car clubs, but that's it. I just want a fun second daily driver that I can have fun with in the canyons. That said the factory brakes with a good set of pads and stainless lines would probably work fine for me, but I'll look into a BBK too. Thanks for the info.
Robert_K
Ranger wrote:Won't be tracking it often, if ever. I have another car for the track. :) Maybe a few open track days with car clubs, but that's it. I just want a fun second daily driver that I can have fun with in the canyons. That said the factory brakes with a good set of pads and stainless lines would probably work fine for me, but I'll look into a BBK too. Thanks for the info.
If that is your goal I suggest the StopTech Stage II kit for the OEM non-Brembos. You can find this kit for around $600 shipped. Good luck!!!
Robert_K
My Engine Bay
Postby Robert_K » Fri Nov 07, 2008 9:14
Robert_K
Postby Robert_K » Tue Dec 09, 2008 9:14
Built motor is a strong possibilty in the coming months. ;)
Postby RX-7 Chris » Tue Dec 09, 2008 9:14
I assume you will be using all forged internals.
Robert_K
RX-7 Chris wrote:I assume you will be using all forged internals.
I feel the need... The need for MORE BOOST!!! :cool:
Oh... Yes. LOL
I figured. What is your power goal now?
Robert_K
RX-7 Chris wrote:I figured. What is your power goal now?
A daily 500whp has always been my goal. Although the 700BB kit (GT28's) are good for 700ish HP.
What about the trans and the rear, will they hold that?
Robert_K
RX-7 Chris wrote:What about the trans and the rear, will they hold that?
I'll upgrade the clutch but they'll both hold.
Robert_K
Gallery Belmont Blue Original Dress Up Parts Installed
Postby Robert_K » Sun Dec 14, 2008 9:14
Thanks to Andy at Performance Nissan. Took awhile to finally receive but I did get them and here are the installed pics. Link to order: MyNismo.com
Users browsing this forum: No registered users and 237 guests
