My 944 Spec car
My 944 Spec car
Postby Ranger » Mon Nov 03, 2008 9:14
Some of you guys have been asking about my 944 for a while now...I finally got some pictures. :) I don't have a camera so I couldn't take any pics of the build process, but I've mostly upgraded suspension, and worked on getting it race legal. Since I got it in March, I've done a lot of stripping, installed a Sparco Pro 2000 seat, changed the rod bearings, installed Koni shocks and upgraded the rear torsion bars (equivalent of springs for rear suspension), lowered it about an inch, upgraded the rear sway bar (in progress), and got an exhaust built for it...it's just about done, and if I get headlights and fix my turn signals it'll be street legal.
Before (when I first got it):
After (from today):
Yes, wheel fitment is pretty ghey. I'm required to run those wheels as part of the 944 spec class rules...any wider / lower offset rims would give too much of an advantage. I'm trying to find some better fitting wheels for the street, unfortunately rims that fit Porsches happen to be crazy expensive.
Too bad I can't lower it any more either. The way the front control arms are designed, they have to be level with the ground or else it'll wear out the ball joints, and they're non-serviceable. It's like $200 to replace a control arm too...oh well. It might not look all that impressive, but it's amazing to drive...even with all-season tires on it handles much better than any other car I've owned, including the FD. Can't wait to get some R-comps on it and take it to the track. :)
Postby Huzer21 » Mon Nov 03, 2008 9:14
That looks like a fun ride. I like pic #2.
Postby MazdaTom » Mon Nov 03, 2008 9:14
Does that side number placard say Hanksville Hot Rods? If so, I was just at his shop on Friday.
Yes it does :) They sponsor the 944 Spec series in the NASA Rocky Mountain division. They built both my roll cage and my exhaust, and both are very well done. What were you at his shop for?
I got my 3rd O2 sensor bung in my mid-pipe plugged. He's basically just down the street from me and found out that he lives REALLY close to me.
Ah that's cool. Hank is a really great guy, plus he does good work. Funny enough I never would have found out about his shop were it not for NASA. The best places advertise via word of mouth it seems...
Postby Colombia28 » Mon Nov 03, 2008 9:14
Sick! So sweet!
