HPFP question
HPFP question
Is it true that Gen pu owners should put a HPFP as a first mod before adding intake or power mods ?
Make sure you don't try to use a regular socket on the 3 inverted Torx bolts. You WILL strip them and you will have a bad time. Just go buy the E8 inverted Torx socket. It's the only job I've ever used that socket for but it was well worth it. You can ask Eric (OCD) about what happens if you use a regular socket, lol. Also use a zip tie around the solid steel fuel line so that the nut doesn't take off way down into the engine bay on you where it will be a HUGE pain to get back.
Only other tip really is to let the car sit for a while before you do it so the lines aren't fully pressurized. This will make it so less gas leaks out of the fuel lines when you disconnect them so it'll be a little less messy.
erod550 wrote:Make sure you don't try to use a regular socket on the 3 inverted Torx bolts. You WILL strip them and you will have a bad time. Just go buy the E8 inverted Torx socket. It's the only job I've ever used that socket for but it was well worth it. You can ask Eric (OCD) about what happens if you use a regular socket, lol. Also use a zip tie around the solid steel fuel line so that the nut doesn't take off way down into the engine bay on you where it will be a HUGE pain to get back.
Where did you pick up this socket?
Checker/O'Reilly/Autozone/Sears/Lowe's/Home Depot should all have them. I got mine at Autozone.
erod550 wrote:Checker/O'Reilly/Autozone/Sears/Lowe's/Home Depot should all have them. I got mine at Autozone.
Thanks man I appreciate it. For some reason this is the only thing on my car that makes me nervous to do. We are doing my downpipe and internal tonight though so we will see how it goes I guess.
The colored ones? If I remember correctly they came off pretty easily.
Number2 wrote:Andy, how did the downpipe install go?
I didn't end up doing it or my internals. I am hopefully doing it this weekend after I dip my car. I had a family emergency so I was at the hospital most of the weekend. I keep hearing that you have to remove a motor mount and lift the motor to do it. You know anything about that? If that's the case I am going to just take it to a shop and have them do it haha
Plus I am trying to find someone to help me do my fuel internals because me and my buddy have never worked with them, I've done engine internals which looks similar considering there are retainers and such, but if anyone could lend a hand in helping me do these I would greatly appreciate it. Because right now I am just on a fuel economy map and my car is gutless.
Users browsing this forum: No registered users and 108 guests
