Starting issue
94mx5
Postby 94mx5 » Wed Jun 22, 2011 9:14
In trying to diagnose the same issue on my van, I threw a spare battery and some jumper cables in back. Turns out there was a small light that would never go off that would drain the battery enough over a couple days. Same symptoms as the starter would click but no turn over due to low power, but different problem.
In the meantime, as mentioned, I would park on a slight downhill. Wouldn't be the first time that saved my butt.
Postby erod550 » Wed Jun 22, 2011 9:14
Yea at home I live on a hill and at work I'm in a parking garage so worst case I can just push it to the ramp going down to the next level and easily jumpstart it. It's been doing this since I bought the thing a year and a half ago though so I'm not too worried about it dying really soon lol.
94mx5
Did it do it before you swapped the engine? I didn't remember any issues from before the engine swap. When you did the swap, you used the "new" starter too, right?
Yea now that I think about it, it started after the swap. We didn't take the starter off so it has the starter from Ron's engine. We did the swap like 2 weeks after I got the car so I guess it just ran together, heh.
Postby RX-7 Chris » Thu Jun 23, 2011 9:14
It is exactly what my car was doing since I got it and about 2 weeks ago the starter completely died.
Postby erod550 » Sun Jun 26, 2011 9:14
Well, replaced the starter and it did the exact same thing on first startup so it obviously wasn't the starter. Oh well, at least now I have a new one and it should last me the rest of the time I have the car. Guy at Autozone said it could be the push button switch, might not be a high enough amperage. I dunno if I care enough to dig it out and try to replace it. Like I said, it's been doing it for a year now and if I'm not worried about the starter crapping out, I will just deal with it. Even though it's a pain, it still does start every time, just sometimes takes more button presses than others.
Postby iani1.1 » Sun Jun 26, 2011 9:14
hm, push button start? thats what i did to mine. wired up a relay and a 60amp push button switch directly to the starter bypassing the electronics. since theres a relay and if wired correctly the car will not start unless its turned to the ign.
I have an S2000 button installed by a previous owner. This pic is not my car but shows the location and the button is the same.
Postby RX-7 Chris » Mon Jun 27, 2011 9:14
I would also look at replacing the battery cables. I had a problem with my other car years ago that I thought was the starter and it turned out to be a bad cable.
Postby erod550 » Mon Jun 27, 2011 9:14
Yea that was my next thought. But with the battery being in the trunk it would be a much bigger pain that replacing it all underhood, heh. Have to weigh which is worse, the pain in the ### replacing the cable or the pain in the ### of pushing the button several times to start the car.
in the end replacing the cables will be the best choice.
Users browsing this forum: No registered users and 193 guests
