RX-7 Chris wrote:I think the VLDS out of the 84-85 rx-7 also fits but you may want to do a little more research on what that takes.
Do they have 4.30 gears? Direct bolt-on or does it require axles/driveshaft as well?
I'll look into it.
RX-7 Chris wrote:They don't have 4.30. GSL came with 3.9 and GSL-SE came with 4.10. The stock axles should work but I think the driveshaft flange is different.
You can look at my car and compare if you want.
ecam8000 wrote:Couple things; I have a Torsen, and in the air it acts like an open diff. With the car idling in 4th (in the air) I can stop on of the wheels with my shoe. On the ground, one side on dirt the other on pavement, both tires spin. A limited slip (clutch pack) will not spin in opposite directions when the car is in the air (unless the clutch pack is toast).
On the other side of the coin. If I had a NA Miata, I would be looking at STS. It sounds like this is a great class for your car. Saturday, did you ever loose forward bite because the inside tire roasted? Sway bar adjustments and suspension settings can do wonders to minimize spin. If you are not having issues with one tire burn outs, the LSD is not really needed. The tires you are running are helping that. Some hard all seasons may need that LSD!
erod550 wrote:Also be careful buying an old used VLSD unless they have tested it. I have read quite a lot of people have VLSD that doesn't work anymore for one reason or another. So it just acts like an open diff.
ecam8000 wrote:Just to add a little bit. Even with my overwhelming additional power from my 1.8 (HA!) I have never spun a tire leaving a corner. I have spun the car many times though.
Users browsing this forum: No registered users and 142 guests
